Sluggish power locks when cold?
Old Jan 14, 2003 | 08:51 AM
Nathan Plemons's Avatar
Nathan Plemons
Default Sluggish power locks when cold?
Is there anything I can lubricate? I've been having to park outside for the past week or so as our new kitchen island takes shape in the garage. In any case I've noticed that my driver's side door lock seems to be kinda slow when it's real cold out.
When the temps are in the 20's and lower I can hit the unlock button and hear the car unlock. The p assenger side goes pretty quickly but I can usually hear a small delay on the driver's side, kinda a sliding thunk rather than the solid clunk. (real technical huh?) By the time I drive to work with the heater on it has warmed up enough that they both operate quickly and in time with each other. Also if it's 30's and above the difference isn't as pronounced, until it gets so warm that they work perfectly.
It has actually not unlocked the driver's side once and I had to use the key. I know the battery is fine, it has to be something on the lock. Any ideas?
Old Jan 14, 2003 | 11:28 AM
fullboogie
Default Re: Sluggish power locks when cold? (Nathan Plemons)
Nathan, mine does this too, even when the temp is only 40 degrees. Kinda weird. I'm interested in any responses.
Old Jan 14, 2003 | 12:41 PM
joecaver's Avatar
joecaver
From: 63.8% of all statistics are made up on the spot.
St. Jude Donor '08-'10
Let me jump on the "me too" wagon.
Old Jan 14, 2003 | 02:42 PM
_freakmonkeydogboy_'s Avatar
_freakmonkeydogboy_
Default Re: Sluggish power locks when cold? (joecaver)
:withstupid:
Old Jan 14, 2003 | 02:51 PM
Marcho Polo's Avatar
Marcho Polo
2023 C8 of the Year Winner - Unmodified
2020 Corvette of the Year Finalist (stock)
2019 C7 of Year Winner (stock)
Former Moderator
Cruise-In I-II-III Veteran
Default Re: Sluggish power locks when cold? (_freakmonkeydogboy_)
:lol: :lol: :lol: :lol:
:withstupid:
I have been meaning to figure this out. Only my passenger side sticks. When I lock the doors, it doesn't lock.
If I find anything, I'll let you all know.
Old Jan 14, 2003 | 03:51 PM
don hall's Avatar
don hall
Hey! Nathan, et al, maybe your door latch mechanism lubricant is just temperature sensitive.
It might gel with a "glue" characteristic as the temp drops. You might try applying a low temp lubricant; or placing heat inside the vette (ceramic heater?); or use your key (like 20 million other drivers do in the morning). With a ceramic heater in the vette overnight, you will getting into a nice warm vehicle in the AM, and maybe the latch mechanism will operate smoothly.
:yesnod:
Old Jan 14, 2003 | 04:47 PM
StealDads67's Avatar
StealDads67
Default Re: Sluggish power locks when cold? (Oldman)
Maybe you guys can hit the mechanical part of the locks with some Graffite.... That should do the trick... Hope this Helps/Works
Old Jan 15, 2003 | 03:21 PM
Rick86's Avatar
Rick86
Default Re: Sluggish power locks when cold? (StealDads67)
I don't know if this will cure a cold temp related problem, but my passanger door lock was slow, so I pulled the door panel and sprayed the linkage and mechanism with white lithium grease. It hasn't given me a problem since.
Old Jan 15, 2003 | 03:32 PM
bill mcdonald's Avatar
bill mcdonald
Default Re: Sluggish power locks when cold? (Marcho Polo)
My 90 does this too on the passenger side door, all the time. It drives me nuts
To Sluggish power locks when cold?
