Is this normal?
Old Mar 17, 2023 | 09:23 AM
rremesal's Avatar
rremesal
Default Is this normal?
Team,
I removed the fan module to look inside the evaporator housing and noticed
No matter what setting I tried, the door did the same. Is this normal?
On a different note, my washer fluid is not making it to the windshield. This is why.
Where can I get this T from?
Thanks,
Ric
Old Mar 17, 2023 | 06:40 PM
rremesal's Avatar
rremesal
Anyone?
Old Mar 17, 2023 | 07:02 PM
s carter's Avatar
s carter
The door action can't totally cover that but, I take it you have the automatic climate control (C-68) but did you try to max out the temperature settings. Because I'm thinking it's kind of floating to maintain a certain temperature.
As for the washer fluid. If you push the button does it **** out there or anywhere else
Old Mar 17, 2023 | 09:02 PM
rremesal's Avatar
rremesal
Yes, I do have the C68, although it doesn't work in auto mode. I have no idea why. I run the AC on recirculation mode. As I started before, I tried different settings, but the door continued doing the same.
isn't the door supposed to close on recirculation mode?
As for the washer fluid, the T is almost completely severed. All the fluid gushes out at the T.
Old Mar 18, 2023 | 01:33 AM
1800Wing's Avatar
1800Wing
Flatulent Dwarf
That fitting falls under the “bulkhead” category more than a classic “T”
. If it were me I’d clip the hose where it’s broken at the fitting, then clean out the bulkhead fitting with a drill bit by hand.
Since you still have some proper size hose left, I’d use some hot glue and shove it back in the hole making sure to give it a straighter approach so you can avoid the acute angle that broke the first one.
If repair is not possible then you could always drill out the bulkhead fitting or remove it entirely, run some new hose through the opening with a standard “T” on the other side to feed the washer nozzles.
later, Tiny
Old Mar 18, 2023 | 01:53 AM
ChumpVette's Avatar
ChumpVette
GM 14057583
Should be able to find it at most corvette part places.
Old Mar 18, 2023 | 02:28 AM
1800Wing's Avatar
1800Wing
Flatulent Dwarf
Chumpvette hit the jackpot…
https://www.corvettecentral.com/c4-8...nnector-654283
GM Parts direct showed it as discontinued but Corvette Central has it in stock, 11 bucks and change.
Later, Tiny
Old Mar 18, 2023 | 07:35 AM
rremesal's Avatar
rremesal
Dang, you guys are good.
Old Mar 18, 2023 | 06:14 PM
1800Wing's Avatar
1800Wing
Flatulent Dwarf
All those years as a male stripper has paid off…!!
later, Tiny
To Is this normal?
