programming the key fob
Old Mar 20, 2023 | 12:34 AM
ncali's Avatar
ncali
Default programming the key fob
98 coup. I tried to program the key fob using the DIC I followed the step by step instructions
found in the ultimate c 5 thread
step 1 turn the radio off and the key on
step 2 press the reset button
step 3 press the options button until the display is blank
step 4 hold the reset button for 3 seconds
step 5 says to press the options button and hold until for training is displayed
When the options button is pressedd in step 5 the options advance to the next choice . it never displays a training message
The car is supposed to have a passive entry system and the tire pressure monitor system works
what can I do to get the key fob to work?
Old Mar 20, 2023 | 08:11 AM
s carter's Avatar
s carter
Here is the C-4 Procedure you can Skip to Minute 2 for programming if your trying to do a C-4 Otherwise your in the Wrong Section.
C-5
Old Mar 20, 2023 | 09:39 AM
ncali's Avatar
ncali
posted in the wrong section. should be c5 section
To programming the key fob
