1986 Tpi engine replacement push rods?
Mar 22, 2023 | 01:12 PM
What are the correct push rods for a 1986 corvette with aluminum heads?
Mar 22, 2023 | 02:38 PM
I forget was 86 flat tappet camshaft? 7.8
if roller 7.2
Mar 22, 2023 | 04:10 PM
Quote:
Originally Posted by
Tunedport90
if roller 7.2
not sure I’m reading now that it is a non roller, so I’m guessing I have to buy 7.8 pushrods is this correct?
So in 87 the only difference was they made it a roller?
Mar 22, 2023 | 04:14 PM
It's not so much a question of what it WAS - What is it now flat tappet or roller?
Mar 22, 2023 | 04:17 PM
WVZR-1
It’s a 100% stock engine, I did pull a valve out to look at it and it was flat with no roller on the end of it.
Mar 22, 2023 | 04:56 PM
Will these work COMP Cams 7812-16 High Energy 7.794" Long, 5/16" Diameter Pushrod Set?
Mar 22, 2023 | 09:41 PM
Or these Melling Pushrod MPR-34-B? Which one of these?
