1988 dash pad removal
Old Jan 15, 2003 | 09:17 AM
dano7vette's Avatar
dano7vette
Default 1988 dash pad removal
Need to remove dash pad in 88. Any tricks of the trade or things to look for? Need to know best procedure. Many Thanks
Old Jan 15, 2003 | 11:49 AM
fixvet's Avatar
fixvet
Default Re: 1988 dash pad removal (dano7vette)
I believe there are about 6 screws.......2 in the defrost opening area and the rest under the lip edge.
Good luck,
Old Jan 15, 2003 | 02:27 PM
vetracer's Avatar
vetracer
I've done it a hundred times. You might need to remove the guage cluster piece to get to the screws going from the tabs behind this piece up into the dash, then the two going from the center I/P up into the dash, the two long ones on each side of the defroster opening on top of the dash and, on some cars there is one on the passenger side behind the fuse panel going up into the dash. I would remove the ones at the defroster opening and along the underside of the instrument panel, and if it won't come out I would look for the one by the fuse panel. Another important tip: make sure not to do all this pulling and squeezing on the dashboard when it is cold, or it may crack. Park it outside for a while in the sun and let it warm up first.
When reinstalling, take your time and make sure all of the tabs go into thier holes on the front of the dash. Also make sure that the clips on the passenger side catch the plastic lip which holds it in place. A little patience here will pay off in the end. Don't overtighten the defroster screws or they will just keep right on going through the dash, and you may get cracks around the screw holes.
You may want to consider going to a fabric store and buying some new speaker grille material if yours have turned purple or faded from the sun. Some spray adhesive will work great for recovering them.
[Modified by vetracer, 7:29 PM 1/15/2003]
Old Jan 15, 2003 | 03:59 PM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
Default Re: 1988 dash pad removal (vetracer)
When you get all the screws out, just pull straight back, (not up!) There are little metal clips fixed to the styrofoam that could break. You don't have to remove the A-piller plastic or anything. It would probably be a good idea to hit the clips with a little wd-40 so it goes on easier, and so they dont corrode if you ever have to pull it again.
Old Jan 15, 2003 | 07:17 PM
kabnvtt's Avatar
kabnvtt
Nice rides you have there vetracer, What off road series are you racing in? The score or snore? I have a good friend that lives in Kingman that I think races the snore events, I believe he runs the class 9. His name Is Joe Sheble just curiuosif you might know him. :cheers:
Old Jan 15, 2003 | 07:57 PM
vetracer's Avatar
vetracer
Default Re: 1988 dash pad removal (kabnvtt)
Thanks. I don't race off road, that photo is from a recent vacation in Cabo San Lucas. My dad, brother, brother in law and I got a chance to drive off road cars with Bob Bondurant from the Bondurant school of high performance driving here in Chandler and one of his friends along the coast of Baja. Because we were with Bob and have racing experience we were able to really tear it up in the rented baja cars and have fun. (they took off the governors and turned us loose on our own, something they normally don't do). It's not a Corvette, but hey, it does have a fiberglass body!
Check out the HUGE cruise ship in the background!
[Modified by vetracer, 6:04 PM 1/15/2003]
Old Jan 31, 2012 | 08:06 PM
norman19's Avatar
norman19
8th Gear
Default 88 dash pad removal
u need 2 remove the bezel around dash cluster then only 5 screws. good luck should b easy.
Old Jan 31, 2012 | 08:13 PM
Caboboy's Avatar
Caboboy
Eight year old thread
Old Apr 20, 2014 | 08:27 AM
Tony Baker's Avatar
Tony Baker
Cruising
Default C4 dash removal
Good luck,
How do you remove headlight button????
Old Apr 20, 2014 | 09:03 AM
WW7's Avatar
WW7
Pull headlight switch all the way out, there's a metel prong on the back of the plastic button, push this prong forward with a small screw driver while pulling on the plastic ****...Should pop right off...From now on you should start your own thread , not tag onto someone elses old thread........WW
Old Feb 12, 2019 | 06:43 PM
Mity2's Avatar
Mity2
oops wrong thread...
To 1988 dash pad removal
