Control Arm Bushings
My question for those who have dealt with a full suite of these is - how much can I expect to pay? My looking online is yielding mixed results about the cost of one tire's worth, vs an axel's worth, etc and the numbers aren't really making sense. I've seen that prothane is a good option for the parts themselves (linked below) but my concern is the labor involved. I don't have a hydraulic press so I can't do them myself, but if I could find one, what's the consensus on the time commitment for the job? The rear ones are by far the worst offenders, so I may do those first anyways, but I'd like to know what my wallet is in for before I call and schedule her in or even ask for one of the shop's quotes in case they're way off. I'd like to order the parts myself and hand them off to the shop, so if anyone has better options than the ones I've found I'd love to hear it!
As always any thoughts are appreciated. Thanks!
Rear Bushings Front Bushings
Edit: I'll also do the ball joints while I'm at it even those are somehow in much better shape than the bushings.
I’m sure any second now the SuperPro rubber bush guys will jump in and say how awful the poly are. To each his own. I’m sure SuperPro rubber bushes are great. I’ve had no regrets in a fully poly bushed car for 5+ years. And no squeaks, thunks, clunks.
I called a local Corvette shop, and while they outsourced alignments they did point me to the shop they use and those guys knew exactly what I was talking about. With a refreshed suspension and a proper alignment you’ll be really amazed at what the car feels like compared to how it drives with it’s currently worn out components.
For this reason - I agree on replacing it all, ball joints, tie rod ends, end links, sway bar bushes, shocks, etc, everything that can wear is worn, these are old cars, now is the time! You will run the bill up a little more but it’s worth it.
this is the thread from when I did the front end of my 94 6 years ago. I had done the rear a few years prior to that. You may find it useful as lots of pics, challenges that the forum helped solve. 6 years later suspension is still great. you’ll start to see in the pics why I did more and more, you find thing when you pull it apart that are at end of life and why bother at all if you’re not going to correct it.
thread…
https://www.corvetteforum.com/forums...-overhaul.html
I've been thinking about it over the day - I think the best option will be to fully do the rear stuff, then do the front when I've got the means. I'll get my head in there, poke around, and give it all a shot myself, just to say that I gave it a go with what little time I have to put towards this (she's a daily for the time being so I can't have her down more than a weekend). If I've got to put it all back together quickly and limp the half block to the shop, oh well, live and learn.
So, in that vein, what else is back there? Right now on my shopping list I've got the control arm bushings, sway bar bushings - 24mm for a '94?, tie rod ends, the ball joints and shocks were inspected and are fine (for now, lol), gonna do the brake pads while I'm at it and scope out stainless lines... Any other rubbery/plastic-y bits that could use changing? This is what qualifies as my introduction to the world of old/aging car ownership and maintenance, so forgive my ignorance on the minutiae.
And at the end of the day, if I can get out of doing just the rear end in the neighborhood of a grand or 1200, I'm happy. The front can wait a (1) season. Many thanks
Another note, else ware on Corvette Forum I have read that the 1996 Composite Dogbones use a different Bushing than the Aluminum ones. This does not seem to be the case with mine, the Super Pro Bushings fit nice and snug in mine.
