another clutch question.
Old Jan 15, 2003 | 10:38 AM
540 vette's Avatar
540 vette
Default another clutch question.
Do I have to change everything(clutch disc,pressure plate,bearing).Or can I just get away with changing just the clutch disc.
Old Jan 15, 2003 | 07:00 PM
SPD DMN's Avatar
SPD DMN
Cruise-In I Veteran
Cruise-In II Veteran
Default Re: another clutch question. (540 vette)
If your pressure plate is in good condition (the surface) and the flywheel is decent, then you "can" change just the plate (I have many times). If you have a lot of miles 70K or more, then it is probably a good idea to go ahead and get a new pressure plate (which comes with a new throwout bearing). This will get your clutch holding pressure back up to spec as well as get a new bearing in there. You can buy just the bearing, but I would suggest getting the whole plate assembly.
