‘84 … what is this sensor please
https://corvetteparts.com/item/senso...tion-1984-1986
Or a 3/4" sensor with a single spade (coolant switch) found by spark plugs in the head
Coolant switch
https://corvetteparts.com/item/sender-ecm-temperature-coolant-fan-1981-1984
Original part number would have been GM# 3040674 that has a somewhat unique connector originally. A connector to match that switch would be a GM# 12102621 and eBay should ID both for you with images. That fan switch does also use the same connector as a knock sensor BUT if the putty looking stuff is at the cylinder head it's a fan switch.
https://corvetteparts.com/item/sende...-fan-1981-1984
Yours is for the ECM temperature sensor and the OP should be able to confirm it's location using FSM 6E2-73, Fig 76
*** Knock Sensor for an '84 in the FSM should be 6E2-90, Fig 99 & 6E2-91 Fig 100
