Coolant temperature sensor?
Old Apr 24, 2023 | 09:20 PM
velvetj1's Avatar
velvetj1
4th Gear
Default Coolant temperature sensor? KNOCK SENSOR
1989 base
I found this above the oil pan on the passenger side, just in front of the starter, with the white part broken off and still connected to a single wire. It’s about 2” long. Google search on the number stamped on the side didn’t give any clear results.
When I took it off nothing came out at first. Until I scraped at the gunk inside and coolant started flowing.
Is this a coolant temperature sensor then?
Looking at new sensors online, they all seem to show a 2-wire connector instead of 1 wire. So that has me slightly confused. Does that matter?
What do I get to replace it?
Last edited by velvetj1; May 2, 2023 at 10:00 AM. Reason: Part correctly identified
Old Apr 24, 2023 | 09:38 PM
Whaleman's Avatar
Whaleman
Knock sensor. Dan
Old Apr 25, 2023 | 09:05 AM
djpink889's Avatar
djpink889
Those have a specific torque setting-when you reinstall make sure you get that right or the knock readings can be affected.
Old Apr 25, 2023 | 09:21 AM
velvetj1's Avatar
velvetj1
4th Gear
Thank you!
Old May 1, 2023 | 06:13 PM
velvetj1's Avatar
velvetj1
4th Gear
Shame on me for not confirming first, but is there only one sensor on a 1989? The passenger side?
All the info and videos I looked up refer to one on each side, but I don’t see one anywhere around the oil filter on the driver side.
Old May 2, 2023 | 05:21 AM
Ray Quayle's Avatar
Ray Quayle
- 1986 Original Owner -
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In VII Veteran
Yep, just the one on your ‘89.
To Coolant temperature sensor?
