Headers and a tune.
Old Apr 29, 2023 | 12:55 PM
Brick330's Avatar
Brick330
Default Headers and a tune.
So in the next couple weeks I'll be putting some long tubes on my 96 lt4. I called and spoke with pcmforless about a tune and he said that I could expect 50hp to the wheels.
I would love to believe this but I'm skeptical about the gains. If anyone with experience with these mods feels like chiming in it would be appreciated.
Old Apr 29, 2023 | 01:04 PM
yakmastermax's Avatar
yakmastermax
Long tubes plus full exhaust and a good tune might result in 50rwhp gain. Might. Tune would have to be meticulous IMO.
Old Apr 29, 2023 | 01:20 PM
Brick330's Avatar
Brick330
It does already have a catback, and i have heard good things about pcmforless on this forum. So I have a chance.
Old Apr 29, 2023 | 01:35 PM
drive it's Avatar
drive it
50 REARWHP gain? nope, don't buy that line.
Old Apr 29, 2023 | 02:05 PM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
I don't think you'll see 50. But then, it doesn't matter much since you're already spending the $$...you'll get what you get, which depends more on....
....how far 'off' the OEM tune is. If the OEM tune is good, you could spend an eternity on the "meticulous" tune, and you won't gain squat b/c the factory was already there.
Old Apr 29, 2023 | 04:29 PM
Krusty84's Avatar
Krusty84
I would think 20-30 rwhp w/ headers/tune as the gen 2 exhaust was really good from the factory. I don't think headers alone will bring 25-35hp like they do on a lot of gen 1 combos.
Old Apr 29, 2023 | 06:02 PM
Mr. Peabody's Avatar
Mr. Peabody
C4 of Year Finalist (appearance mods) 2019
I would take a little time to decide where you're going to have it "run on a dyno" to determine the amount of gain in RWHP. You definitely want to do a before and an after-tune run on the same type of dyno and preferably on the same unit in the same shop.
You have an LT4 so you already have some better components (stock) than came on my 95. On my 95 A4 I had the LT4 hot cam kit installed (including 1.6 rockers & springs which I think you already have stock on the LT4), along with HD timing chain & sprocket kit, all new ignition system components oh .... and stainless works LT headers with RT cats into the stock cat back dual exhaust.
The install work and the custom tune on the dyno were all done by Tom Wong at Wongs Performance Engineering on his mustang dyno. I gained approx 40RWHP on my engine. Full disclosure I ASKED for a mild tune. I was not interested in peak hp as much as I was interested in increasing the area under the torque curve .... and longevity. All this work was done 70,000 miles ago and the car still runs like a top.
I think that Tom400CFI made a good point, your RWHP increase will depend on how far "off" the OEM tune is.
Please let us know how it works out!
Old May 21, 2023 | 06:36 AM
Brick330's Avatar
Brick330
After a day of working on the 96 the headers are on. I just need to tie up a few odds and ends today.
One of those is spark plugs, I know that some of you have made a "custom " plug wrench. I was hoping that you guys could share how you went about this.
Thanks again
Old May 21, 2023 | 11:04 AM
yakmastermax
@MrPeabody
What was your final rwhp on the 1995 LT1 with long tubes, factory catback, cats, and LT4 Hot Cam Kit?
310rwhp? Also do mustang dynos read a little higher or lower?
I have had good luck removing and installing spark plugs on my L98 cars with Hedman Elite Long tube headers using a 5/8" offset box end wrench
Old May 21, 2023 | 03:22 PM
Mr. Peabody
@MrPeabody
It was just around 300. My understanding is that a Mustang dyno tends to read a bit lower. That's why I think it's important to perform both the before and after mod runs on the same dyno to properly determine what the "improvements" yielded.
Old May 22, 2023 | 07:41 AM
Brick330's Avatar
Brick330
Headers are officially. I need to send out my pcm for a tune and I should be good!
Old May 22, 2023 | 10:28 AM
vader86's Avatar
vader86
50 nope, a good tune could get you a chunk but I wouldn't buy 50rwhp.
Old May 22, 2023 | 11:49 AM
Brick330's Avatar
Brick330
Been driving it today and the new noises it makes are very nice. I will say it feels a little more sluggish in low RPMs now, but once I'm past 1500ish it really picks up! Cant wait to get it tuned!!!!
Old May 22, 2023 | 06:38 PM
Brick330's Avatar
Brick330
@MrPeabody
What flavor of offset wrench do you use?
The "S" shaped kind or the step in kind?
Old May 23, 2023 | 12:05 AM
yakmastermax
I take that back, I actually had more luck using a 5/8" spark plug socket that had an end in was turning with large study wrench, 3/4 maybe
Old May 23, 2023 | 03:20 PM
Brick330's Avatar
Brick330
That's how i did most of them, but cylinder #2 has a pipe so close it it i cant get a standard plug socket onto it.
Old Jun 11, 2023 | 01:32 PM
Brick330's Avatar
Brick330
Default Headers and no tune dyno results.
282hp and 301tq before the tune. Im running very very rich.
To Headers and a tune.
Old Jun 11, 2023 | 05:10 PM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
7 hp and 1 pound.
Well....that's something. Wish we could see the whole piece of paper. Tune should help, if it's rich, but a/f looks about the same in both pulls. hard to tell w/no scale.
Old Jun 11, 2023 | 06:14 PM
Brick330's Avatar
Brick330
Originally Posted by Tom400CFI
7 hp and 1 pound.
These runs where back to back, never had it on the dyno stock unfortunately.
Here's the full sheet
Old Jun 11, 2023 | 09:11 PM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
Oh! That makes a lot more sense! I should have figured that out on my own.
Yep, it's pretty rich. How about that ~295RWTQ at 2500 RPM? I Love it! This is great data. I dig it.
