Help needed on fuel pump not working
Old Apr 30, 2023 | 02:00 PM
Anthony DiChario's Avatar
Anthony DiChario
1st Gear
Default Help needed on fuel pump not working
My 996 LT-4 fuel pump is not receiving a trigger wire signal after the ignition is turned on. there is no fuel pressure. If I hotwire the pump lead it will run and build pressure. I have replaced the spark plugs, battery, fuel pump relay, pressure regulator and fuel pump. Does this model corvette have an inertia impact sensor switch? I can find no blown fuses. This car has not been started in two years. SOMEONE HELP PLEASE.....
Old Apr 30, 2023 | 07:26 PM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
If you look at the schematic you will see B2 is your “trigger” or control side feed…B5 is load side feed and if you connect a 12 volt test light to ground and probe B2 the test light will illuminate for 2 seconds with key ON and then go out…it’s usually pin 85 or 86 if you look at your relay…B5 will be “hot” in run and start…when you find load side feed if you go diagonally across the fusebox you will see B1…to check that ground connect that test light to battery POSITIVE and probe B1…if the ground is good (G106) the test light will illuminate !!
