roller rockers
Old May 2, 2023 | 09:37 PM
GaryInArizona's Avatar
GaryInArizona
Default roller rockers
HI was wondering if any added performance.
by putting 1.6 roller rockers on my stock LT-1. Thanks .
Old May 2, 2023 | 11:03 PM
Garage Hermit's Avatar
Garage Hermit
I was just researching that question myself. This article involves a higher lift than stock cam but the same principle applies.
With a 1.6:1 rocker, this gives us 0.508-inch valve lift at max lift, an increase of 0.031 inch. It doesn't sound like much, yet it was enough to show a sizeable gain, mainly because it increases the amount of time that the valves are open at higher lifts, allowing more air to flow through the heads.
Old May 3, 2023 | 09:05 AM
Orion2011's Avatar
Orion2011
Yes, Upgrade the valve springs at the same time. Rollers add mass and the higher lift can cause coil bind.
Old May 4, 2023 | 10:51 AM
GaryInArizona
Thanks for the info guys I'm going to give it a try ?
To roller rockers
