L98 vs. LT1
Old Jan 17, 2003 | 01:46 PM
robertpel9's Avatar
robertpel9
Default Re: L98 vs. LT1 (Red84CrossFire)
I have a 91 Convertable (L98) i used to own an 84 4+3 car (L83 engine). To be honest i did not notice a huge difference in performance between the two motors. I mean yes the 91 is smoother and a little faster but i was underwhelmed the first time i drove it and it did not blow my 84 away. Same thing i noticed with my L98 and the LT1's. I have driven many and can not really tell much difference. I know there is a difference but i don't personally think there is enough of a difference between a 91 L98 and a 92 LT1. I had the opperitunity to buy either my 91 vert in pristine condition for the same price almost as a 94 coupe on the lot that was in good condition but not perfect. I went with the 91 and have no regrets. Thats my 2C cents. I'd rather have what i consider the most refined 1st gen SBC vs. the first year of the new design. I'd be happy with either if i were you but i am glad i got what i did.
Old Jan 17, 2003 | 02:17 PM
LT195's Avatar
LT195
Default Re: L98 vs. LT1 (a1970stingray70)
Its a matter of preference but I was told the newer the vette the better.
:steering:
Old Jan 17, 2003 | 04:09 PM
dgoodhue's Avatar
dgoodhue
Try searching on this subject, it has been covered a lot of times. This is a heated subject and it doesn't need to be rehashed over and over.
Old Jan 17, 2003 | 04:19 PM
Steel Blue 91's Avatar
Steel Blue 91
Default Re: L98 vs. LT1 (dgoodhue)
:withstupid:
Agreed. Time to move on.
Old Jan 17, 2003 | 04:48 PM
Rick93Z07's Avatar
Rick93Z07
Default Re: L98 vs. LT1 (Steel Blue 91)
Spend a weekend Permatex sealing and adding '96 vent-purge to the '92-'94 early OptiSpark unit for $17. Plugs take about 4 hours every 30K miles, if you have a 3/8" swivel head ratchet and you're admiring your work and being extra careful so you don't damage the wires. The LT1 will need a new Optispark around every 100K mi, if it's properly modified to prevent fluid penetration and H2O moisture build-up. A smart owner will use an Optispark replacement/mod project as a no-brainer opportunity to change plugs and wires.
I'm not sure a weekend of work to correct the Optispark weaknesses and 4 hours every couple years for a spark plug change would sway my vote either way.
I think it'll take a ton more labor than I described above to add 50 HP to a L98. Many folks add cat-back, intakes, TB's, gears, heads, cams and even swap trans to close the gap. Of course, you typically get what you pay for. The '86-1/2 cars are real cheap, assuming you are satisfied with stock performance & you're not going to dump a bunch of $ and labor for mods into it. Let's not forget that modifying clean, stock Corvette of either type will not significantly increase it's value. Modifications are a poor monetary investment. From a resale perspective, if you want LT1 (or early C5) acceleration, you should buy an LT1 (or early C5) respectively, in order to minimize labor and recoup your investment at a later date.
Old Jan 17, 2003 | 09:30 PM
Zora's Avatar
Zora
Cruise-In I Veteran
Cruise-In II Veteran
Default Re: L98 vs. LT1 (Drewdog)
I don't think the General would have designed the LT1 with the intention of it being inferior to the previous engine
No...they sure would not. :cheers:
Old Jan 18, 2003 | 08:38 AM
BiZ's Avatar
BiZ
Default Re: L98 vs. LT1 (Zora)
I've said it once and I will say it again. Buy a LT5 and have the best of both worlds. Plenty of low end torque for those stoplight warriors and upper RPM horsepower that is second to none.
Old Jan 18, 2003 | 08:58 AM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
:withstupid:
Old Jan 18, 2003 | 01:10 PM
The Example's Avatar
The Example
Cruise-In III Veteran
Cruise-In IV Veteran
Default Re: L98 vs. LT1 (BiZ)
Hey! We're trying to keep the discussion under 300rwhp here
