L98 vs. LT1
Old Jan 16, 2003 | 03:50 PM
a1970stingray70's Avatar
a1970stingray70
Default L98 vs. LT1
All things considered if both cars are in the same condition including mileage.
Between a 1991 L98 or a 1992 LT1. Which one would you pick???
Taking in to account the opti-spark and more horsepower compared to the less hp L98 and no opti-spark. Also isnt it easier to change spark plugs in the L98???? So which is the better most trouble free and easier to maintain vette the L98 or LT1 and which one would you pick?????????????????
Old Jan 16, 2003 | 04:02 PM
91drptop's Avatar
91drptop
Default Re: L98 vs. LT1 (a1970stingray70)
Is the glass half empty or half full? I have the L98 and if the plugs are easier to change, I DON'T want to try it on an LT1! Goo dluck in your choice and enjoy the ride
Old Jan 16, 2003 | 04:04 PM
scorp508's Avatar
scorp508
Between those i guess it is "do you like stoplights or highways".
Old Jan 16, 2003 | 04:35 PM
ROADAPPLE's Avatar
ROADAPPLE
Default Re: (scorp508)
Boy, you sure do know how to open up a big can of worms, don't you!
LT1 :boxing L98
Old Jan 16, 2003 | 05:13 PM
TA's Avatar
TA
Here we go again :lurk:
FD2BLK's Avatar
FD2BLK
All things considered being the same with both cars I would still choose witch ever car I liked best because they are both good motors I might lean a little to the 92 just because it is a year newer.
Old Jan 16, 2003 | 05:22 PM
The Example's Avatar
The Example
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Default Re: L98 vs. LT1 (ejfagala)
I have a cherry '87 L98 in the neighbors garage (he had extra space for it) :)
I also own a '94 6 speed.
I used to own a '91 L98 automatic.
Now, as far as interior designs go, I like the black on white gauges instead of the gray on orange color of the 91.
As far as engines go, the '94 would have run circles around the '91, and though I haven't had an '87/94 grudge match, I expect to beat the asthmatic L98 handily.
Enginewise, there is NO comparison. The LT1 is far superior despite some of its mechanical drawbacks (spark plugs, optispark). If you worry about moisture damage, buy a Meziere water pump. Thats what I did...
LT1 all the way.
TreyZ28's Avatar
TreyZ28
Lt1 has lighter pistons, reverse cooled heads, better intake manifold, an optispark, and some other worthless nonsence
It amazes me-
L98 owners say the L98 is better than the LT1
Lt1 owners say the LT1 is better than the LS1
:banghead:
The Lt1 is superior to the L98 overal from a design point of view
More gas effiecent, cleaner, powerful etc
an opti and intake is all that really seperates us-
opti problems are over rated. its like a clutch. it will go every 80k miles. deal with it.
Ls1 owns us all :cheers:
Old Jan 16, 2003 | 05:31 PM
Raistlin's Avatar
Raistlin
Default Re: L98 vs. LT1 (TreyZ28)
If your looking for a driver, not strictly a race car (where, you'll change everything anyway), just buy the newest, lowest milage vette with the options you want, that you can afford.
they all have their ups and downs. I think the LT1 will be cheaper to mod, if you stick to around 370rwhp, after that, it evens out a bit. A total race car would be similar money to make.
Old Jan 16, 2003 | 05:41 PM
vader86's Avatar
vader86
Default Re: L98 vs. LT1 (Raistlin)
Id do the same thing we've told you the last 10 times you asked, get the newest vette you can afford.
Old Jan 16, 2003 | 05:50 PM
vetracer's Avatar
vetracer
Maybe changing the spark plugs is more difficult on the Lt1 than it is on the L98, but when changing injectors, it is definitely the other way around.
Old Jan 16, 2003 | 06:39 PM
scorp508's Avatar
scorp508
It amazes me-
And F-body owners say F-Bodies they are better than Y-Bodies :jester
Old Jan 16, 2003 | 06:50 PM
Dr. Evil's Avatar
Dr. Evil
CI 1-2-3-4-5-6-7-8 Veteran
CI-IV AutoX Champ
CI-IV Burnout Champ
St. Jude Donor '07-'10
Default Re: L98 vs. LT1 (scorp508)
Heres my take having owned and modded a 90 6 speed coupe and now having an LT4. The 91 L98 is the last, and best design of the the SBC and L98. The bugs and flaws are worked out. The 92 is the 1st year of the LT1. My Mom has a 92 vert 6 speed. I cant tell a nickel worth of fit and finish between hers and my 90. My 96 is another story. The late L98 has lightweight pistons too and decent rods as well. I bet theres not 2 tenths difference between 2 identical cars (auto vs auto/ manual vs manual). With 2k in mods my 90 ran mid 13s at 105 mph with a few 106 trap speeds. This was at the cruise in when other LT1 autos were trapping at 101 and 102mph. If it were ME and for my use I would choose the 91 hands down for the type of driving I do.
Someone mentioned something about gas mileage. My 90 got 29.7 mpg on no less than 8 700mile round trips from Mo to East Tn. My Lt4 doesnt get near that, and its pretty much stock.
[Modified by red90sixspeed, 5:52 PM 1/16/2003]
Old Jan 16, 2003 | 06:51 PM
Drewdog's Avatar
Drewdog
I don't think the General would have designed the LT1 with the intention of it being inferior to the previous engine
Old Jan 16, 2003 | 06:52 PM
TreyZ28's Avatar
TreyZ28
It amazes me-
I'll see you at the end of the drag strip :lol:
(runs before scorp invites him to autocross)
Old Jan 16, 2003 | 06:54 PM
Dr. Evil's Avatar
Dr. Evil
CI-IV AutoX Champ
CI-IV Burnout Champ
Default Re: L98 vs. LT1 (Drewdog)
The General didnt intend for alot of things to happen but they did nonetheless.
Old Jan 16, 2003 | 10:20 PM
CarAteMyMoney's Avatar
CarAteMyMoney
Default Re: L98 vs. LT1 (red90sixspeed)
If you want a cheap setup to beat on every day, go with the L98 - that's exactly why I bought mine. It's not as fast as my friend's 96, but tuneups are a hell of a lot cheaper.
Keep in mind the LT-1 is also much more modern in terms of engine controls. It's designed to take L98 technology to the next level. I wouldn't say the L98 is inferior to the LT-1 only because technology has its drawbacks (maintenance etc) But then again, I still don't consider carburetors inferior to EFI only because the advantages and disadvantages almost cancel each other out.
If money weren't a factor, though, i'd take the '91. All around mix of performance, and maintainability (if that's a real word. if it's not, I just invented it! :D )
To L98 vs. LT1
Old Jan 17, 2003 | 12:29 AM
Zora's Avatar
Zora
Cruise-In I Veteran
:leaving:
Old Jan 17, 2003 | 12:19 PM
Bruthish's Avatar
Bruthish
St. Jude Donor '03-'04-'06-'08-'09
man...doesn't he make posting so much fun? :lol: :lol:
Old Jan 17, 2003 | 12:44 PM
my02cents's Avatar
my02cents
Default Re: L98 vs. LT1 (Bruthish)
Crossfire, all the way.
Was that an option? :lol:
