Remove passenger air outlet ? How?
Old May 9, 2023 | 05:25 PM
Sportdoc's Avatar
Sportdoc
Default Remove passenger air outlet ? How?
1995 Coupe
Trying to get to the cruise control module to test.
Per the FSM: Remove-
1. (Disable SIR -check)
2. Fuse box cover and I/P Side Trim Panel -check
3. Right Air Outlet Assembly. ??? I can get it loose on the sides but what's holding it in the center? It's being held in there, but I can't figure out how, and don't wanna break any of those delicate plastic parts.
4-12 Cruse control module.
I'm still not sure where I'm going to find the C/C module. Is it nearer to the Right door, or to the radio?
Please help.
Old May 9, 2023 | 10:39 PM
Sportdoc's Avatar
Sportdoc
Yes, I have the 1995 FSM
Old May 9, 2023 | 11:03 PM
Desert Rider's Avatar
Desert Rider
You need to gently pry out the center louvered insert and then there are 2 torx screws behind it
Old May 10, 2023 | 02:50 PM
Sportdoc's Avatar
Sportdoc
Thanks.
I'll do just that.
Any ideas where I should be looking to locate the C/C module? Toward the door, or toward the center?
To Remove passenger air outlet ? How?
