Electrical
Old May 23, 2023 | 04:14 PM
Philipbair's Avatar
Philipbair
4th Gear
Default Electrical
I have a 1988 Corvette. I pulled the left door panel off and must have shorted out something when I was prying off the Five prong plug on the door. The electrical system is now dead. I have checked all fuses in the block and all are OK. Where to look now?
Old May 23, 2023 | 04:48 PM
s carter's Avatar
s carter
How dead. as in Nothing No interior, No Headlights, No Crank
Old May 23, 2023 | 10:38 PM
jv9999's Avatar
jv9999
If that's the power door lock switch, it's fed by a 30A circuit breaker in the panel. It's supposed to automatically reset, but it could be bad. Always use plasic tools when prying off connectors :-)
Old May 23, 2023 | 10:47 PM
GaryInArizona's Avatar
GaryInArizona
Or disconnect your battery, good luck on your repair
Old May 25, 2023 | 11:08 AM
Philipbair's Avatar
Philipbair
4th Gear
Dead, as in 100% dead. No starter, no lights, no anything. I was thinking fusible link so I pulled the battery. Nothing found as yet
Old May 25, 2023 | 11:10 AM
Philipbair's Avatar
Philipbair
4th Gear
I knew better than use a screwdriver but just got in a hurry. All the fuses in the panel are good..
To Electrical
