89 C4 won’t crank
Old May 24, 2023 | 02:30 PM
l_gurrola28's Avatar
l_gurrola28
2nd Gear
Default 89 C4 won’t crank
Looking for help
Parked the car one day and the next morning it would not want to start. Thought it was a vats issue installed a bypass kit and still won’t start or crank. New battery doesn’t drop below 12 on trying to start. Cleaned the battery terminals as well. I added a video trying to start it. I am a novice so any help would be really appreciated
File Type: mov
Old May 24, 2023 | 03:10 PM
stew86MCSS396's Avatar
stew86MCSS396
From: Liliha Bakery stuffing my face with coco puffs!
Start interrupt relay???
https://www.corvetteforum.com/forums...post1589340975
Old May 24, 2023 | 05:48 PM
l_gurrola28
2nd Gear
Originally Posted by stew86MCSS396
Watched a video on how to bypass that and still nothing. Pretty sure I did it right “connected a wire between the green and white striped wire and a yellow wire.” If you at anything else that I would try I would appreciate that.
Old May 24, 2023 | 07:11 PM
stew86MCSS396
On one side of the connector that you bypassed, you should see 12v when you attempt to crank. If not work towards the ignition switch. Could be a misaligned park/neutral switch. I've seen couple of people mention messing around with the tilt steering as well. If you do have 12v at the bypassed connector while cranking, then work towards the starter solenoid...
Old May 27, 2023 | 05:25 PM
64Scout's Avatar
64Scout
I had an intermittent no start and it was the contacts in my starter solenoid. They were cheap to replace.
To 89 C4 won’t crank
