Window seals
Old Jun 7, 2023 | 11:31 AM
jaclar's Avatar
jaclar
Default Window seals
I have an 89 and desperately need new window seals, any recommendations? I’m struggling to find any online
Old Jun 7, 2023 | 02:15 PM
2011KLR's Avatar
2011KLR
Do you meam the window scraper? https://www.rockauto.com/en/catalog/...per+seal,12406
Old Jun 7, 2023 | 03:19 PM
jaclar's Avatar
jaclar
Originally Posted by 2011KLR
is this the rubber between the door and the car? I’m new to this so I’m not sure what it’s called
Old Jun 7, 2023 | 10:06 PM
2011KLR's Avatar
2011KLR
Search for Corvette Rubber. They got most everything funner for Corvettes.. whouddathunk it 😎
Old Jun 8, 2023 | 01:07 AM
slammin's Avatar
slammin
Corvette Rubber Co is the place to go for C4 weather stripping. Their products aren't cheap, but they are the best. I have never heard a complaint. You don't have to buy the complete kit, they sell most seals separately.
Old Jun 8, 2023 | 01:49 AM
Mike Blanchard's Avatar
Mike Blanchard
are the outer window wipers difficult to install? I have a new set, but haven't wanted to tackle it yet LOL
Old Jun 8, 2023 | 12:41 PM
dburgjohn's Avatar
dburgjohn
I think your are like mine. Remove inner door cover, drill two rivets and pull out. Assembly is just as easy. Toughest part is not breaking plastic on door panel you remove to access screws. Not only keeps water out, makes a big visual difference.
Old Jun 8, 2023 | 12:47 PM
Mike Blanchard
are the rivets in brackets or on the actual door skin itself?
I have to replace the window regulator track gear on drivers side anyway, so the door will be apart, I was thinking about doing the wiper then too while it's all apart ;-)
Old Jun 9, 2023 | 11:44 AM
Prtjm3's Avatar
Prtjm3
Navigator
Where did you get the outside window seal? Corvette rubber doesn’t seem to have them.
Old Jun 9, 2023 | 12:18 PM
slammin's Avatar
slammin
Most vendors sell them. They are listed as "Door window seal kits" and include 2 inner and 2 outer pieces to do both doors. I have a current Zip catalog and they offer them for under $100. I sure others vendors do as well. There are several U tube videos showing the replacement procedure.
Old Jun 9, 2023 | 02:17 PM
Mike Blanchard
oh I got these a year maybe 2 years ago at this point. AM AutoParts is on the label, I ahven't even opened up the shipping tube they came in yet LOL
Old Jun 10, 2023 | 12:06 AM
2011KLR's Avatar
2011KLR
Rodney Dangerfield impression... "Is this thing on?"
Old Jun 11, 2023 | 09:54 PM
dburgjohn's Avatar
dburgjohn
on the ends of the strip
Old Jun 12, 2023 | 12:01 AM
Mike Blanchard
sorry, you mis understood. I wasn't referring to the wiper portion, but the door itself.
For some reason I had it set in my head that the wiper was riveted or stapled to the door skin itself. I see through some videos that it is on a bracket attached to the door. Super easy replacement :-)
Old Nov 2, 2023 | 07:59 AM
woodman369's Avatar
woodman369
8th Gear
Default Window seal kit
Zip no affiliation they have just about everything you may need for a corvette.
To Window seals
