No brake lights
Old Jun 12, 2023 | 04:59 PM
WICKED Z's Avatar
WICKED Z
Default No brake lights
Any common problem on c4 when the brake lights dont work? I have someone wanting me to look at this problem . Maybe just a brake lite switch ??
Old Jun 12, 2023 | 06:06 PM
billschroeder5842's Avatar
billschroeder5842
Zen Vet Master Level VII
That was my first thought as well.
Old Jun 13, 2023 | 04:19 PM
89corvettemann's Avatar
89corvettemann
When i had no brake lights it was the white wire from the turn signal switch. This wire feeds the brake light switch.
Old Jun 15, 2023 | 09:12 AM
64Scout's Avatar
64Scout
The white wire takes the signal from the brake light switch and feeds it to the blinker switch. But in any case, without it, only the center brtake light will work since it is a separate circuit.
Old Jun 15, 2023 | 10:11 PM
Spencer Smith's Avatar
Spencer Smith
I've put 2 or 3 brake light switches in my 91 over the past 3 years. I've never had total a failure though, just the 3rd brake light going inop.
Old Jun 16, 2023 | 09:35 AM
jrobin1's Avatar
jrobin1
Two issues I encountered for no brake lights were: 1) there is a connection in the steering column that became corroded and I had a chevy dealership fix it during my route 66 road trip. 2) the bulb sockets have some gunk, "old grease" i believe, that will interfere with the connection and cause failure.
Old Jun 16, 2023 | 09:58 AM
WVZR-1's Avatar
WVZR-1
If you still have operational 'directional & hazard' the SLS (Stop Light Switch) would be certainly the first check!
To No brake lights
