84 corvette idles rough
Old Jul 7, 2023 | 11:55 PM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
Take 'em out and see if they're clogged up w/carbon? It's possible one was broken all along, and the other just broke now.
Old Aug 4, 2023 | 11:06 AM
joeys61's Avatar
joeys61
Hey! sorry for the late reply again, got back from vacation a few days ago. Anyway, Great news! While cleaning both the IAC valves didn't do much to fix the problem, replacing them and the coolant temperature sensor and setting the timing fixed my idle! no more pops, no more shakes, no more 1800rpm idle, it idles great now! I'm not sure if the coolant sensor had any issues or not but I've heard they're problematic so I figured I'd replace it anyway since they're pretty cheap and would probably save me a headache later on. Thanks for the help, everyone!
Old Aug 4, 2023 | 11:26 AM
fparkin's Avatar
fparkin
coolant sensors on 84 corvette, can drive you nuts hell my ran good sometimes and bad i finally changed it and all problems went away .i put new style on mine. my wires were burnt on mine so they make connection most time
Old Aug 4, 2023 | 03:15 PM
Frogman 1984's Avatar
Frogman 1984
Cruising
I know mine will shake and idle. Around 1k when it is warming up, but as soon as it’s warmed up it chills out.
Old Aug 7, 2023 | 03:05 PM
wilcar's Avatar
wilcar
[QUOTE=ssro;1606748994]im saying my motor di shake alot because it was timming was at 0 did the same exaust sound. i know that spark plug wires go from 1,8,4,3,5,6,7,2 but he did say he put the wires back in place.[/QUO. You did mean 18436572 firing order, right??
Old Aug 7, 2023 | 03:43 PM
fparkin's Avatar
fparkin
this is correct is 18436572 firing order,
