Rear end alignment? What do you think?
Old Jan 18, 2003 | 04:21 PM
Lichen_1's Avatar
Lichen_1
Default Rear end alignment? What do you think?
I just installed a rebuilt differential from zip products 3.54 and I am going through the break in period. I have noticed that when going faster than 70 mph and I accellerate the rear feels like it wants to thrust slightly to the right side and when I leave off the accellerator it sorta shifts back to the left. While maintaining a constant speed the car will drive dead straight with my hands off the wheel. Does this sound like I need a rear wheel alignment? Speeds below 70 it doesn't seem to do this.
Old Jan 18, 2003 | 10:37 PM
Lone Ranger's Avatar
Lone Ranger
Default Re: Rear end alignment? What do you think? (Lichen_1)
<edit>
[Modified by Lone Ranger, 9:52 AM 1/19/2003]
Old Jan 19, 2003 | 02:25 AM
No Go's Avatar
No Go
This answers my other post...
If you disturbed the rear camber settings (large eccentric on bottom of the diff) then you need an alignment...pretty simple really. Can't eye ball or it drives like your does.
Camber will mess up your toe as well.
Old Jan 19, 2003 | 08:06 AM
Lichen_1's Avatar
Lichen_1
Default Re: Rear end alignment? What do you think? (No Go)
I only removed the camber bracket from the differential, and did not losen the bolt to the adjustment washer. So I don't think that I messed with the original setting, unless simply switching the differential may have ofset something what do you thing "No Go"?
Old Jan 19, 2003 | 11:51 PM
Lichen_1's Avatar
Lichen_1
Maybe Im psychotic but I think the problem is starting to go away. I would still like to know why it did this (and still does a little bit).
Old Jan 19, 2003 | 11:59 PM
h rocks's Avatar
h rocks
Get an alignment. Have you checked the runout on your rear wheel bearings? How are your rear toe rod ball joints? Bushings? Any or all will make your car squirrely.
Old Jan 20, 2003 | 12:29 AM
Shriker's Avatar
Shriker
Definitely get the alignment checked. Well worth the money to be sure the car is aligned correctly. These cars are very adjustable and can act quite differently with different alignments in front or back or both.
Next, the "yaw" from left to right when getting on and off the gas usually has to do with rear tie rod ends . Mine did the same thing (pretty severely) when I bought it. I replaced the rear tie rod ends and it cured the problem.
Hope that helps, good luck. :seeya
Old Jan 20, 2003 | 12:31 AM
vader86's Avatar
vader86
Default Re: Rear end alignment? What do you think? (h rocks)
:withstupid:
Old Jan 20, 2003 | 08:20 AM
Lichen_1's Avatar
Lichen_1
Default Re: Rear end alignment? What do you think? (vader86)
Ok you guys have convinced me, I will definitely get a rear wheel alignment. I just thought of something to check as well that I will do when I get off work. Maybe tire pressure?! I have felt a car do this in the past with low tire pressure, I don't know why I didn't think of that earlier.
Old Jan 20, 2003 | 08:26 AM
Lichen_1's Avatar
Lichen_1
"h rocks", yes I did inspect those closely and they look like they are in great condition. This car is from Florida, has 45k miles and has always been pampered so I don't really expect anything to be wrong with wear and tear on the rear end; however, I could be wrong.
To Rear end alignment? What do you think?
