Bogs down
Old Jun 25, 2023 | 10:20 PM
Itsnate1998's Avatar
Itsnate1998
Default Bogs down
It starts right up and runs good I took it for a short drive earlier today and it ran perfect. I just tried to go to the store and I came to a red light whenever it was my time to go it bogged down when I gave it gas. It straightened out whenever I kept pumping the throttle. But any idea why it would bog down whenever I try to go?
The temp was around 180 when it started to bog down
I’ve replaced
-fuel pump and filter
-plugs and wires
-Icm and coil
-iac valve
-tb position sensor
​​​​​​-coolant sensors
-map sensor
​​​​​​-maf sensor
and a few more things I can’t think right off the top of my head
Old Jun 26, 2023 | 12:55 AM
stew86MCSS396's Avatar
stew86MCSS396
From: Liliha Bakery stuffing my face with coco puffs!
I’ve replaced
-plugs and wires
-Icm and coil
-iac valve
-tb position sensor
-map sensor
​​​​​​-maf sensor
You changed out the MAF sensor? Got a good part number for that?
Old Jun 26, 2023 | 06:41 AM
Itsnate1998
my apologies it was a
Intake Manifold Temperature Sensor. Part number 213-243
Old Jun 26, 2023 | 06:04 PM
stew86MCSS396
No apologies necessary, I just wanted to know if you were throwing out legit remarks of parts being replaced as your '92 doesn't have a MAF sensor. Anyhoo...if everything as you say seems to check ok then this would be me throwing a dart at a clogged cat. Never experienced it myself so can't comment further.
Old Jun 26, 2023 | 10:01 PM
Itsnate1998
I’ll definitely check it out. Thank you for the input
To Bogs down
