Steve40th back on the road again
Old Jan 18, 2003 | 08:44 PM
steve40th's Avatar
steve40th
St. Jude Donor '03 & '05
Default Steve40th back on the road again
Well, motor is running good so far. No oil or water or even exhaust leaks. I am going ot drive around the state today, well the little island of Oahu, and see what happens. I let it run throught the heat cycle of the fans going on and off and oil up to 200 degrees, and I am going to let it cool down, and then go drive. Any suggestions for "Break in", let me know. Thanks
Old Jan 18, 2003 | 08:54 PM
Speedracer176's Avatar
Speedracer176
Default Re: Steve40th back on the road again (steve40th)
might as well put your foot into it. If its going to break then its going to break.
Old Jan 18, 2003 | 08:55 PM
Raistlin's Avatar
Raistlin
glad to hear that! :cheers:
i missed your post on what you decided to do to fix it.
did you just replace the valve and put it back together?
Old Jan 18, 2003 | 08:57 PM
steve40th's Avatar
steve40th
Default Re: Steve40th back on the road again (Raistlin)
I replaced valve and springs, the guide was good according to machine shop. Deburred the piston.
Old Jan 18, 2003 | 09:02 PM
J Z06's Avatar
J Z06
glad to hear you're up and running! :cheers: :cool:
Old Jan 18, 2003 | 09:43 PM
ittlfly's Avatar
ittlfly
Default Re: Steve40th back on the road again (JD 90 383)
:cheers:
Old Jan 18, 2003 | 11:19 PM
Raistlin's Avatar
Raistlin
sounds good :cheers:
i don't think there'd be much in the way of a break in for the new parts, i'd just drive it like you allways do.
To Steve40th back on the road again
