1984 c4 a/c pressure switch
Old Jun 28, 2023 | 02:11 PM
Mkmit's Avatar
Mkmit
2nd Gear
Default 1984 c4 a/c pressure switch
What is the switch called which is attached to the rear, high side of the compressor? AND WHAT MAY THE PART NUMBER BE, WHERE TO PURCHASE
Old Jun 28, 2023 | 02:58 PM
WVZR-1's Avatar
WVZR-1
'84 has a fan switch which is compressor mounted. The switch that's connected to the compressor manifold is a pressure cycling switch. The cycling switch is a GM# 10007057 and the fan switch which is retained by a snap-ring is a GM# 2724279. Those numbers are OE/GM original and the 10007057 is a difficult find.
Old Jun 29, 2023 | 08:31 AM
Mkmit's Avatar
Mkmit
2nd Gear
Thanks for the info, that helps a lot.
To 1984 c4 a/c pressure switch
