Need help - stranded and not really running.
There was a major rain storm while she was at work and when she tried to come home it wouldn't start. I get there and find it cranks, gets fuel, but no spark.
I replaced the #25 fuse in the passenger side fuse box (water made it through the a pillar weatherstripping to the passenger floor board) I then pulled the 2 60amp maxis for the ignition system from the engine bay box they were corroded so I swapped them.
The car then had spark and I was able to start it but only by punching the gas pedal while cranking.
Car blew white smoke out the exhaust that I attributed to rain water having gotten in the exhaust pipes.
After revving it while parked for a couple minutes white smoke went away and engine idle stabilized.
We started the 30 mile drive home and after a bit it started running progressively rougher. At the 10 mike mark I pulled into a Lowes parking lot because any time I gave it any level of gas the car was shaking (not engine knock the car was shaking). By the time I was stationary in Lowes it won't idle on its own. Only lights that came on were service asr/abs.
I pulled all the maxi fuses from the engine bay fuse box and cleaned them up (didn't have enough to replace them). They were all corroded. After reinsertion and restart the asr/abs lights cleared but engine still needs gas pedal to start and now shakes at idle (though it will idle on its own).
After three hours tinkering in the dark in a parking lot we called it for the night. I'm open to ideas. The car was running fantastic prior to this.
I verified all wires are connected to the opti, plugs, ignition module and coil. Oil level is good per the dipstick. Tranny fluid is good per the dipstick. I need to check coolant level somehow that slipped my mind.
Car has power 14.5 volts at the battery all lights come on. I didn't have a fuel pressure gauge but got plenty of gas spraying out the Schrader valve when I checked it.
Any and all suggestions are welcome. Thanks.
First thing today I siphoned some gas out of the tank - no evidence of water in the gas. I dropped in some heet anyway.
Checked fuel regulator vac line - no fuel leaked out.
Attached fuel pressure gauge. Turned key to run. 40ish psi that immediately dropped to 20 and after a couple seconds 5-0.
Cranked car - kachunk.
Turned on dash battery gauge it showed 11.8 volts. Hooked up jump box - gauge then showed 12.5 volts, cranked again - kachunk. While cranking battery gauge indicates voltage dropped to 5-6volts.
Tried using jumper cables instead of jump box. With jump vehicle running and cables connected battery gauge indicated 13.5 volts. Cranked again - kachunk.
Pulled battery took it to auto parts store for testing - test results say it's a good battery with no loss.
It started raining so we had to call it a day.
Other data: pulled #2 and #4 plugs both are slightly dirty but nothing major. No mechanical regapping (thank the Lord) no accumulations. Replaced maxi fuses located behind the battery because why not. Replaced all the fuses from the passenger side fuse box that are listed as having anything to do with the engine/ignition/etc.
Any ideas? Yesterday I got it started and drove it probably 10 miles. The more I think about it the more I think the shaking I experienced yesterday was due to fuel starvation. But even if fuel pump is dying that doesn't explain why power isn't getting to starter etc.
Any ideas? Yesterday I got it started and drove it probably 10 miles. The more I think about it the more I think the shaking I experienced yesterday was due to fuel starvation. But I have no idea why power isn't getting to starter etc.
if with kachunk you mean engine isn't turning over check there's no hydrolock (pull all spark plugs).
Sorry "kachunk" is turn the key to crank and starter makes a single noise/effort that sounds pretty much like kachunk. Starter doesnt crank engine doesnt turn over.
When I go out tomorrow I'll try turning the engine over manually - should have done that when I was there. However I don't think it's hydrolocked since my wife says the "kachunk" is the same noise it made prior to my arrival on scene yesterday and we charged the battery and drove it 10 miles after that.
I'll add I rechecked oil and coolant levels both indicate in normal ranges. Also while driving it yesterday oil and coolant temps (via digital readout) were both sub 200 (~195-198).
I appreciate the assistant keep the advice, thoughts, comments coming!
... How would I do that?
the solenoid pulls in and engages the pinion. That’s what makes the noise. But the starter motor gets no power. You can replace the starter or replace just the copper contacts.
I would pull all plugs and look for a cylinder with raw gas in it. The injectors might be new but one could still be leaking if it’s defective or got some crud in it.
Good news :
Found a great tow company with a low profile deck truck that got it home without hurting the car.
Bad news:
I checked the oil once we got it home... The dipstick was perfectly clean... And smells like gasoline. I'm going to bed now.
Rechecked the oil - still none on the stick and smells like gas (I was really hoping I just imagined that).
Popped the intake tube off the throttle body so I could try turning the engine manually - there is oil in my intake tube.
Engine does appear to turn over with the breaker bar so at least didn't imagine that either.
This weekend I'll get it in the air and drain the 'oil' to see what we have in the pan.
Coolant color, clarity, and level all look good. So that's something I guess.
