Coolant Temp 299!?
Old Jul 15, 2023 | 03:52 PM
Shunyun's Avatar
Shunyun
Default Coolant Temp 299!?
My Coolant Temp guage climbs steadily to 299 and stays. I just replaced the Thermostat. Also, the Low Coolant warning stays on, even though I just had the coolant flushed at Jiffy Line. The Oil Temp gauge says “Lo” (oil pressure is 53 at idle). The aux fan goes on when the coolant temp shows 285.
I’ve just now been running it at idle with the hood up, in the garage (it’s about 85F outside) and after about 15 minutes the main fan started and oil temp is 165. It’s been about 25 minutes and the oil is at 230. Oh, and the low coolant warning light is off.
Those aware of my recent posts know that I made a mistake and got oil in my radiator; I’ve flushed that.
Any suggestions on how to troubleshoot?
Old Jul 15, 2023 | 04:44 PM
Purple92's Avatar
Purple92
I'd suggest starting with an IR temp "gun" to see if the measurements at the thermostat housing / radiator inlet are in rough agreement with what the temp gauge says.
And is this temp measurement based on the "analog" gauge, or is this based on the coolant temp show in the DIC (LT1 cars).
Old Jul 15, 2023 | 04:58 PM
Shunyun's Avatar
Shunyun
This is an 88, so the digital display.
Old Jul 15, 2023 | 05:00 PM
Shunyun's Avatar
Shunyun
Also, I used an oven temp probe and the temperature did not get over 180.
Old Jul 15, 2023 | 05:11 PM
Incorvettei's Avatar
Incorvettei
Are you reading metric?
Old Jul 16, 2023 | 01:02 AM
Shunyun's Avatar
Shunyun
Nope
Old Jul 16, 2023 | 08:31 AM
arbee's Avatar
arbee
If 299 was indicated in celsius, that would be 570° in fahrenheit. Would be some kind of engine to reach that temperature and still run.
Old Jul 16, 2023 | 09:29 AM
Purple92's Avatar
Purple92
I don't really trust an over temp gauge, but assuming that the oven temp gauge is close to correct - I would start by changing out the temp sensor...
Old Jul 16, 2023 | 09:09 PM
Shunyun's Avatar
Shunyun
OK, update.
Did some more research here and found a few mistakes I made; the main being that when I filled the coolant I only did it at the radiator, when I should have also filled the engine at the thermostat.
Then I read some articles that got me a bit concerned that perhaps I may have blown a gasket.
So I filled the engine and then got a combustion leak tester. Good news is that the fluid stayed blue. Also the oil is still clean.
BTW, on the subject of the leak tester; no one, in what I read here or on the tester instructions, warned me to replace the radiator cap when I’m done with the test. By that time, the thermostat is open and the fluid is circulating. I turned off the engine and hot radiator fluid spewed!
So, cleaned that up and now waiting for the engine to cool down, then will top off at the thermostat again and at the radiator. Then I’ll test again.
Old Jul 16, 2023 | 10:25 PM
Shunyun's Avatar
Shunyun
OK, update.
Old Jul 17, 2023 | 10:05 AM
Whaleman's Avatar
Whaleman
My opinion is it did not really get to 299 and continue to run. Dan
Old Jul 17, 2023 | 09:02 PM
Shunyun's Avatar
Shunyun
I ensured that it was really topped off… and everything works. It’s 100F today and I drive it to get tires then smogged (it passed!) and the temp stayed below 230. Drive away from the light, get up to speed, and goes down to 212ish.
So then here’s my theory, somebody correct me if I’m wrong.
I think that, because it was truly low, the fluid was not contacting the temperature sensor so the sensor was really getting that high but the rest of the engine was not. I’m just guessing, really don’t know why it would get that high but not do damage. But like I said, passed smog, oil’s clean, no funny smells, idle and runs solid.
To Coolant Temp 299!?
