Speed Bleeders -- do they work???
Old Jan 20, 2003 | 08:22 AM
Tom Piper's Avatar
Tom Piper
Default Speed Bleeders -- do they work???
Does anyone have speed bleeders, and do they really work?
Tom Piper
Old Jan 20, 2003 | 11:08 AM
Zora's Avatar
Zora
Cruise-In I Veteran
Cruise-In II Veteran
Default Re: Speed Bleeders -- do they work??? (Tom Piper)
I have them on mine..........Yes,they do work. :yesnod:
Old Jan 20, 2003 | 12:09 PM
enhance's Avatar
enhance
They work great, I will never use regular ones on any car I ever do now, it makes it so much easier.
[Modified by enhance, 9:10 AM 1/20/2003]
Old Jan 20, 2003 | 01:11 PM
Phil-tha-Rush's Avatar
Phil-tha-Rush
Default Re: Speed Bleeders -- do they work??? (lani's 93)
Would someone mind describing the speed bleeders and how they are installed and operate. I've read some brief info about them, but it's not clear if you remove the original bleed valve in the caliper and replace them with a speed bleeder or what?
How do you use them?
give this link a try. I think it will answer your questions :D
http://www.speedbleeder.com/
Old Jan 20, 2003 | 03:46 PM
pablocruise's Avatar
pablocruise
I installed them very recently after also replacing stock rubber lines with braided steel lines. Bleeding the system was cake!!! I am very happy with them. All air came out real easy and pedal is firmer than ever! BTW, I found mine at Autozone for $10.00 a pair. Get some, it makes servicing the system way easier.
Old Jan 20, 2003 | 03:52 PM
jaa1992's Avatar
jaa1992
From: Life is just one big track event. Everything before and after is prep and warm-up and cool-down laps
Cruise-In III Veteran
Cruise-In IV Veteran
St. Jude Donor '12
Default Re: Speed Bleeders -- do they work??? (89 Paul in Cal)
Thats what I paid for them online from Summit (local places didn't have them).
Size is 10mm x 1.0 if you need to know. I'll be putting them on the vette before spring!
[Modified by jaa1988, 3:53 PM 1/20/2003]
Old Jan 20, 2003 | 07:17 PM
1SLO POK's Avatar
1SLO POK
Default Re: Speed Bleeders -- do they work??? (jaa1988)
I have or I should say had. Mine worked great the first time I used them. Then a couple years later I had to bleed them again, and only one worked. the others looked liked they where frozen.
But if you where to ask me if I would buy them again, I probably would.
Old Jan 20, 2003 | 07:34 PM
john3154's Avatar
john3154
Is that the same size for GS brakes?
Old Jan 20, 2003 | 07:52 PM
Rynda's Avatar
Rynda
I'll bet something like this would work on the clutch system too.
Old Jan 20, 2003 | 08:07 PM
Zora's Avatar
Zora
Cruise-In I Veteran
Default Re: Speed Bleeders -- do they work??? (1SLO POK)
Did you put the caps on them? If you don't........Dirt,etc..will get in the bleeders. Bleed mine a few times over the pass three years....No problems. :cheers:
Old Jan 21, 2003 | 04:59 PM
John Row's Avatar
John Row
Default Re: Speed Bleeders -- do they work??? (john3154)
:yesnod:
To Speed Bleeders -- do they work???
