Hood left open
Old Aug 2, 2023 | 03:14 PM
PapaFred's Avatar
PapaFred
Default Hood left open
This is my first C4 so am not sure its likes and dislikes. Can I leave the hood open for long periods? It is on a battery tender unless driven. The previous owner took the under hood bulbs out for show purposes, and never back in.
Thank all
Old Aug 2, 2023 | 03:19 PM
s carter's Avatar
s carter
As long as the under hood lights are unplugged or removed you can leave the hood up inside a garage it doesn't matter
Old Aug 2, 2023 | 03:32 PM
PapaFred's Avatar
PapaFred
Good to know, thank you
Old Aug 2, 2023 | 04:00 PM
Fiberbundle's Avatar
Fiberbundle
Most owners just unplug the under hood lights rather than removing the bulbs. Follow the wiring down to just over the side marker lights to check if the PO just unplugged them.
Old Aug 2, 2023 | 06:04 PM
PapaFred's Avatar
PapaFred
Roger that, thank you
Old Aug 2, 2023 | 06:21 PM
vader86's Avatar
vader86
I leave mine open most of the winter while its on a trickle charger.
Old Aug 2, 2023 | 07:04 PM
Incorvettei's Avatar
Incorvettei
Sure, you can leave the hood open as long as you want. Wont harm anything as long as the under hood lights are disabled
Old Aug 3, 2023 | 08:02 AM
Whaleman's Avatar
Whaleman
Or put a switch on each. Dan
Old Aug 3, 2023 | 09:06 AM
2011KLR's Avatar
2011KLR
Nice!
Old Aug 3, 2023 | 09:54 AM
PapaFred's Avatar
PapaFred
A really great idea....I see a small project coming up....the list is growing
Old Aug 3, 2023 | 10:19 AM
Whaleman's Avatar
Whaleman
Get high output LED bulbs and you will be amazed how bright they are with less amp draw. If I remember I will take a picture after it gets dark in the garage. Dan
Old Aug 3, 2023 | 10:37 AM
slammin's Avatar
slammin
At least one of the usual Corvette parts houses markets a kit that plugs into the factory wiring so one provided switch shuts off both lights. The price is just north of $100. Those of us that are very thrifty, just unplug them.
Old Aug 3, 2023 | 10:48 AM
Whaleman's Avatar
Whaleman
I just bought two toggle switches at the local Ace hardware. Dan
Old Aug 3, 2023 | 07:15 PM
sheriffjim's Avatar
sheriffjim
I've left my hood open for months at a time. I went down to oreilly and got some cheap toggle switches for the underhood lights.
Old Aug 4, 2023 | 09:32 PM
PapaFred's Avatar
PapaFred
Where can I find those LED bulbs, a special Vette store or Autozone and the like? I like the idea as they also "should" draw less volts.
Old Aug 4, 2023 | 10:15 PM
sheriffjim's Avatar
sheriffjim
I went to Oreilly with my old bulbs and found some LED's that were the same size and they went right in.
Old Aug 4, 2023 | 10:17 PM
PapaFred's Avatar
PapaFred
That works,...thank you
To Hood left open
