problem codice H62 H72 Asr
There are two signals from the opti-spark that go to the ECM. One is a high resolution pulse (high res) and the other is a low resolution pulse (low res). Everything is not normal if you are getting this code (it means the ECM is having issues with the low res signal...can be the opti, the harness or *maybe* (unlikely) the ECM itself, maybe bad grounds). The ECM uses the two opti-signals to know where the engine's rotating assembly position is so it can fire the correct injector bank at the right time and adjust spark timing etc... I know the engine can *run* without one of the signals but I thought the low res one was the critical one. Without both signals the ECM cannot even tell the engine is spinning.
Do you have some mechanical ability yourself? Are you able to inspect the opti harness and make sure the connectors are clean and tight? Are you able to clean up and inspect grounds? If you have the FSM are you able to follow the troubleshooting guide for code 16 (you should do this before any further mechanical work)?
https://www.corvetteforum.com/forums...post1603353269
