85 c4 corvette ground locations
Old Aug 12, 2023 | 12:57 PM
Canadiansdrivevettes's Avatar
8th Gear
Default 85 c4 corvette ground locations
Hey, I’m new to C4s and I’m having a problem with my digital gage cluster where everything lights up but it’s very dark and really hard to see when the sun hits it, I think I’ve narrowed it down to the ground wires having a bad connection but I don’t know where they are, If anyone has any thoughts on what could be the problem and maybe where the ground locations are, thanks.
Old Aug 12, 2023 | 02:04 PM
s carter's Avatar
s carter
There's a couple of things to look at, have you looked at the back lighting in the dash cluster all it takes is 1 of them to be out and the effect is very noticeable. Usually when a ground is poor the dash will scramble and flash, but 1 of the grounds is on the Left side "A" pillar just above the carpet there another 1 on the "B" pillar that covers the other things in the dash (probably a redundant) also there is a ground that gets pretty corroded given it's location is on the frame wing under the heater box under the hood.
Start with the back lighting
Old Aug 12, 2023 | 07:24 PM
8th Gear
I have not looked at the back lighting, will try that first to see if it makes a difference then I will look at the ground if that doesn’t work. Thanks I will post if both don’t work.
Old Aug 12, 2023 | 10:31 PM
2011KLR's Avatar
2011KLR
Grab some polarized sunglases and look at it.
To 85 c4 corvette ground locations
