msd help idle smoother??
Old Jan 21, 2003 | 01:16 AM
DRAGRCR1005's Avatar
DRAGRCR1005
Default msd help idle smoother??
does any one have experience with a msd on a lt1. my car has a rough idle, not real rough(not felt in the car only heard in the exhaust) but rough enough to drive me crazy. i have read different threads and have found that some people have experienced the same problem and the msd seemed to fis the problem. if you have a msd, which is it, digital or standard? :flag
Old Jan 21, 2003 | 05:20 AM
5abivt's Avatar
5abivt
Default Re: msd help idle smoother?? (DRAGRCR1005)
your car should idle smooth. if it doesnt, something is wrong. fix it first, MSd will help but it is only a band-aid fix.
Old Jan 21, 2003 | 07:33 PM
DRAGRCR1005
Default Re: msd help idle smoother?? (5abivt)
i wish i could find it. i am begining to think that it is just supposed to run like that. already replaced the following...opti, wires, plugs, fuel pump, fuel filter, air filter, and did a top engine clean. no change!!! it runs real smooth when cold, then when it is hot it has a slight pop and thud coming out of the exhaust. you do not feel anything, but i put muffler elim. pipes on the car and now it is very noticable through the pipes??? any ideas??? :cry
Old Jan 21, 2003 | 10:32 PM
ittlfly's Avatar
ittlfly
Greg, I sent you an IM...
To msd help idle smoother??
