overheating lt1
Old Aug 25, 2023 | 03:13 PM
c4bomb's Avatar
c4bomb
Default overheating lt1
i recently bought a 1993 zf6 and 3 days after i brought it home it started over heated. I bought a thermostat that i have not installed yet. All coolant components of the car are from factory and the previous owner did not care for the car at all. This is my first time working on a American car and i see it more as a resto project that i rly want to be able to daily. any advise and tips are welcome
Old Aug 25, 2023 | 03:59 PM
yakmastermax's Avatar
yakmastermax
Flush coolant and replace with fresh.
Inspect radiator for debris by removing shroud.
Clean and remove debris if present.
Old Aug 25, 2023 | 04:41 PM
2011KLR's Avatar
2011KLR
1) buy the service manual for your car
2) read a lot of threads
Old Aug 25, 2023 | 05:47 PM
Talfryyn's Avatar
Talfryyn
After the car cools down check the radiator hoses and see if any are collapsed. If so replace the coolant reservoir cap.
200f is normal. Fans come on at 220f. Go by the digital readout not the gage.
replace thermostat. Read up on how to drill a hole in the thermostat and on how to bleed air out of the system.
Old Aug 25, 2023 | 05:55 PM
Cruisinfanatic's Avatar
Cruisinfanatic
From: Clifton Park, NY ............Clearwater, FL ... 85 Original Owner
i recently bought a 1992 6zf and 3 days after i brought it home it started over heated. I bought a thermostat that i have not installed yet. All coolant components of the car are from factory and the previous owner did not care for the car at all. This is my first time working on a american car and i see it more as a resto project that i rly want to be able to daily. any advise and tips are welcome
Get the radiator out would be the first thing. Most likely looks like this. Then replace the thermostat
Old Aug 26, 2023 | 10:03 AM
'78CorvetteS.A.'s Avatar
'78CorvetteS.A.
All of the above^^^^, and read the "Sticky" thread on C4 cooling in the C4 General section👍
Old Aug 27, 2023 | 06:22 PM
c4bomb's Avatar
c4bomb
thank you all, my radiator wasnt as dirty as the one in the pic and the hoses seemed in fair condition. i ordered a thermostat and will install it when it gets to me. Will update.
Old Aug 28, 2023 | 01:53 PM
93 ragtop's Avatar
93 ragtop
Wait....... Could you answer a few questions first.
1. What is the temperature that it is overheating to? FWIW 230 or a little more is common (and normal) at idle or stop and go traffic.
2. Does it overheat all the time, only at idle, or only when driving at speed.?
FWIW there are lots of things it can be from low coolant, dirty radiator, bad t-stat, bad fans, bad relays, bad sensors, just to name some.
More info is needed.
Oh, and by the way, the LT1 t-stat is specific to that engine, (different design from SBC) and the FACTORY one is rated at 180 degrees F.
Old Aug 29, 2023 | 11:57 AM
c4bomb's Avatar
c4bomb
1. one time i took it to 260 then turned it off and heard it boil. It overheats all the time, at idle and while driving. im going to check if the rad is clogged and do a flush. the fans are turning on so ive ruled them out already. yea i ordered the t-stat on rock auto so i believe i should have gotten the correct one
Old Aug 29, 2023 | 01:38 PM
Mr. Peabody's Avatar
Mr. Peabody
C4 of Year Finalist (appearance mods) 2019
You might also consider replacing the radiator pressure cap.
As others have suggested ....... this is a very good read:https://www.corvetteforum.com/forums...peratures.html
Old Aug 29, 2023 | 06:51 PM
'78CorvetteS.A.
I feel doing a cooling system pressure test would be a good idea, just to make sure you don't have a bad head gasket(s) or cracked head(s)! 260°F is too hot IMHO, you won't get away with that too many times. Hope you get it figured out👍
Edit: Also, using a infrared laser pointer thermometer is great way to verify actual temperatures all over the engine, hoses and radiator!
Old Aug 31, 2023 | 08:21 AM
93 ragtop's Avatar
93 ragtop
ok, the next thing I would do is start it up, let the temperature come up to 200 or so, then start misting or lightly spray the radiator with water. If the temperature drops or stays steady, it is most likely a radiator problem. You could pull it and clean it , but IMO on a 31 year old radiator, I would replace it. It appears they are $125.00 for a standard replacement from rock auto, so about $150.00 all in.
Old Sep 8, 2023 | 01:00 AM
c4bomb's Avatar
c4bomb
im thinking of getting a aluminum rad just because i will be driving the car hard. Is the DeWitt aluminum rad a known good one.
Old Sep 8, 2023 | 07:47 AM
Whaleman's Avatar
Whaleman
I sure am happy I bought one. They were a tad cheaper when I got mine. Dan
Old Sep 9, 2023 | 09:52 AM
69mako's Avatar
69mako
Run a pressure test on your system. A coolant pressure test kit is not expensive.
You'll need it to check for leaks and to ensure the system is holding pressure.
Old Sep 9, 2023 | 10:22 AM
Bizaro1824's Avatar
Bizaro1824
4th Gear
Could be as simple as changing the air filter. Not cleaning, changing. About 30.00 on Amazon. They tend to get overlooked and never get changed. Clean air filter easy job and can make a world of difference.
Old Sep 10, 2023 | 12:51 AM
AmoriFati's Avatar
AmoriFati
One other thing. Check with ac on if both fans work. If only one fan works it is very hard for this car to run cool
To overheating lt1
Old Sep 10, 2023 | 09:33 AM
arbee's Avatar
arbee
As I am always open to learning new CORRECT information, I would be interested in knowing how a dirty air filter would cause an engine to overheat. Keeping a clean air filter is a given but changing it would stop overheating???? That's a new one.
Old Sep 11, 2023 | 09:16 AM
c4bomb's Avatar
c4bomb
the engine filter should not cause over heating. maybe if it was low on power but that is not the case.
Old Sep 11, 2023 | 09:39 AM
c4bomb's Avatar
c4bomb
Yea i was looking into getting one but before i buy one im going to get a block tester since im not leaking the coolant
