Longer Lug Studs????
Old Jan 21, 2003 | 11:18 AM
85superram's Avatar
85superram
Default Longer Lug Studs????
Where would I get a set of longer lug studs???? I need them in order to correct an offset problem. Who makes them and how much????
Old Jan 21, 2003 | 01:26 PM
ski_dwn_it's Avatar
0ski_dwn_it
Former Vendor
Default Re: Longer Lug Studs???? (85superram)
I will be watching this. I need them for my 89 to be legal at the strip. The stud must enter the *head* of the lug by the diameter of the stud. Mine are a tad short if they get picky, but then again I don't have a cage yet, so that will be the least of their worries I would guess :D
Old Jan 21, 2003 | 01:52 PM
tpi 421 vette's Avatar
tpi 421 vette
Default Re: Longer Lug Studs???? (ski_dwn_it)
Doug Rippie Mototsports has them. 1-612-559-7605 or http://www.dougrippie.com
Old Jan 21, 2003 | 03:43 PM
85superram's Avatar
85superram
Default Re: Longer Lug Studs???? (tpi 421 vette)
Hey thanks a lot, good price on them too.!!!!!
Old Jan 21, 2003 | 03:50 PM
scorp508's Avatar
scorp508
Going full slick? :)
Old Jan 21, 2003 | 08:07 PM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
Got mine from Lingenfelter
Old Jan 21, 2003 | 09:07 PM
ski_dwn_it's Avatar
0ski_dwn_it
Former Vendor
Default Re: (scorp508)
been full :D
Old Jan 21, 2003 | 09:15 PM
Guest
Guest
Posts: n/a
Default Re: (ski_dwn_it)
you can go to moroso.com and look them up there also, they a $9.98 for a pack of 5 from summit racing, only difference is they are standard thread instead of metric, :cheers:
Old Jan 22, 2003 | 12:39 PM
4GTWRK's Avatar
4GTWRK
A lot of the TCC racers are using GM # 22551491. I tried the ones from Rippie and had trouble with stripped threads. I switched to the GM studs and have had great success, plus they are a little longer with a pilot on the end of them.
Dave
Old Jan 22, 2003 | 08:29 PM
mvitacco's Avatar
mvitacco
Dorman #610-323 is m12x1.5x54mm with the correct knurl.
They are about .5 inch longer than stock and found at any CarQuest
for about $2.50 per stud.
If you need longer, ARP does wheel studs for most GM cars. Most Speed
Shops will carry them or call Summit Racing.
Old Jan 22, 2003 | 08:45 PM
oldjoe's Avatar
oldjoe
Default Re: Longer Lug Studs???? (Mr Mojo)
Lingenfelter looks the best to me. They are extra long and are metric. The price is $29.95. Joe :chevy :chevy
To Longer Lug Studs????
