Is my fuel pump bad?
Old Sep 3, 2023 | 02:08 PM
Jfoutch88's Avatar
Jfoutch88
8th Gear
Default Is my fuel pump bad?
My '91 fires up, but will only continue to run if I rev the engine and keep the rpms up. When I let off the gas it immediately stalls. Does this sound like I have a bad fuel pump? If not, what's the next P.O.A.?
Old Sep 3, 2023 | 02:11 PM
s carter's Avatar
s carter
Fuel pressure check and fuel sample to see if it's contaminated with water.
Next the last time fuel filter was replaced
Also have you ever cleaned the throttle plates
Old Sep 3, 2023 | 03:04 PM
2011KLR's Avatar
2011KLR
It could also be a dead IAC.
Old Sep 3, 2023 | 05:13 PM
Jfoutch88's Avatar
Jfoutch88
8th Gear
Replaced filter last summer. And it was almost empty so I threw 5gal of 91 octane in it.
Old Sep 11, 2023 | 12:53 PM
Polo Vert's Avatar
Polo Vert
Could also be a vacuum leak.
To Is my fuel pump bad?
