C4 1984 bugging problem
Old Sep 3, 2023 | 05:42 PM
ssro's Avatar
ssro
Default C4 1984 bugging problem
So whrn i start it its fine, first 10 mins it fine when i press on gas i have power revs fine, but 15-20 min in cruzing i press on gas and it bugs and sluginsh, wont rev
Old Sep 3, 2023 | 07:19 PM
Jud Chapin's Avatar
Jud Chapin
St. Jude 15 Year Donor
St. Jude Donor '11 thru '25
Take a look at the fuel sock. It might be bending under suction. I went thru this with my ‘84 once. It got to where it would barely run.
Old Sep 4, 2023 | 01:40 PM
VikingTrad3r's Avatar
VikingTrad3r
Oil Producer
Default plugged 85 fuel sock for reference.
would start and idle and even run. but as soon as you asked for much throttle it would vacuum itself shut. required turning it off and back on the release the vacuum.
Old Sep 11, 2023 | 10:30 AM
Whaleman's Avatar
Whaleman
Also could be the ICM is getting hot and messing up. Dan
To C4 1984 bugging problem
