1984 Throttle Body
Old Sep 28, 2023 | 02:57 PM
Mrshaund79's Avatar
Mrshaund79
Default 1984 Throttle Body
I somewhat feel like I seen a thread before about upgrading the throttle body, but cannot find it, Was trying to find the alternatives to go with?
Old Sep 28, 2023 | 11:51 PM
flannel_man's Avatar
flannel_man
Cruise-In VI Veteran
@Buccaneer
Old Sep 29, 2023 | 07:35 AM
84 4+3's Avatar
84 4+3
On a stock vehicle... there really isn't a need to do anything to them.
Old Sep 29, 2023 | 10:16 AM
mike1111's Avatar
mike1111
stock tb will out flow stock intake manifold.
Old Sep 29, 2023 | 10:21 AM
Mrshaund79's Avatar
Mrshaund79
I am porting the stock manifold this winter and changing to e-street heads
Old Sep 29, 2023 | 10:52 AM
84 4+3's Avatar
84 4+3
It's still more than adequate.
Old Sep 29, 2023 | 11:24 AM
Mrshaund79's Avatar
Mrshaund79
Awesome thanks.
Old Oct 3, 2023 | 11:27 PM
iceman2003's Avatar
iceman2003
Hope you put a nice cam some roller rocker arms 1.6:1 and a good header to make those heads breath. Have fun porting and polishing your intake. Next spring let us know your results. The TPIS SuperL98 Cam is mild but should give you a nice boost over stock. Good Luck...
Old Oct 5, 2023 | 10:11 AM
Phobos84's Avatar
Phobos84
Years ago before I LS swapped my 84 I built a 383 with Edelbrock heads an Xram intake and a comp cams marine roller cam. I sent the throttle bodies out to be bored out bigger. I had to buy bigger throttle blades to do it and sent those with the bodies to get bored. Then I used the "cop car" injectors and tuned it with a 7747 ECU. A forum member named Dominic helped me tune it.
Not sure how much the bigger throttle bodies helped. But it wasn't that expensive to have done. Eventually I wanted more power than I was ever going to get with that setup so I LS swapped with a 4L80e. But the 383 ran ok. It was way too expensive overall though. A junkyard 5.3l with a cam would make more power.
To 1984 Throttle Body
