Comp Cam + Mini Ram, Worth it?
Old Oct 4, 2023 | 08:44 AM
lorenzo1987c4's Avatar
lorenzo1987c4
Default Comp Cam + Mini Ram, Worth it?
Hey everyone,
I've been debating on tackling a new project this winter. I have a 1987 Corvette with a stock motor. I've seen people who have cam swapped without taking the engine out which is one of the main reasons I want to do this since I don't have a garage. My question is, would upgrading the cam and adding a miniram be worth the labor, $$$$, and HP/TQ gains? What can I expect in power gains? I've seen people say to just build a 383 at that point but again, I don't have the resources to pull the engine.
Here's the set up I'm thinking:
  • TPIS miniram
  • Comp Cam - 08-501-8
  • and of course better springs and rockers
Let me know what you guys think and if there's any other mods you would recommend to compliment this setup. This thread may be what causes me to proceed or terminate this project so any thoughts are welcome.
Old Oct 4, 2023 | 09:40 AM
vader86's Avatar
vader86
It would be fine as a driver upgrade, you will need to budget a custom chip.
You would really need some head porting to get the most out of it. The '128s are ok but don't flow as well as the '113s.
Headers should be in the plan.
Old Oct 4, 2023 | 05:21 PM
yakmastermax's Avatar
yakmastermax
What is your budget?
Car is stock right now?
Smog requirements on car?
Current gears and transmission?
Best bang for the buck and labor is going to be long tube headers and a free flowing dual exhaust.
After that I would consider an all in one combination, Miniram, heads, and a cam, plus a tune.
Miles on motor? The AFR Enforcer 195 heads could be a solid budget option with a Miniram on a 350, and an appropriate cam for those heads.
Factor in your tune... you either need to be able to swap chips and have someone burn chips, or go to an EBL or go to an aftermarket ECU.
Old Oct 4, 2023 | 07:08 PM
lorenzo1987c4
thanks for the reply. do you know anyhting about DIY porting? I saw once that someone lined up the new intake gasket to the old head ports and he outlined the head with a sharpie using the inner part of the gasket. He then used a dremel to widen it out. is that a good idea?
if you couldn't already tell, i'm new to modding engines. been watching people do it for years but never actually got my hands dirty
Old Oct 4, 2023 | 07:09 PM
lorenzo1987c4
Budget is probably $1500, engine and trans (55K miles) are stock and I've also been thinking about registering as an antique to not worry about smog anymore.
Could you send a link for the headers you are currently running? Do they include the bungs for AIR or did you delete that?
Old Oct 4, 2023 | 08:05 PM
yakmastermax
Total budget is $1500?
Stock automatic or manual transmission?
Being allowed to delete the smog stuff helps simplify and cheapen the exhaust upgrade.
I have put Hedman Elite 68448 headers on 3 different C4 Corvettes. They are not smog compliant. Using them means deleting the smog and EGR stuff. There are reasons not to do that, but I have done so on all my C4s.
They are basically the lowest tier long tube header i would recommend for a C4 Corvette, and are the cheapest at $700 for the pair or so.
With a $1500 budget, assuming you have a stock 1987 exhaust, system, I would put all that money into a set of long tube headers, and a dual exhaust system. That will eat up most of the change.
Cam and intake can come later. If you have $250-$450 left over after doing the exhaust you could throw on some 1.6 ratio full roller rockers to net some more lift, duration, and free up some horsepower.
I have a thread called something like "1989 full exhaust upgrade headers 68448" that has lots of pics and explains a lot.
Old Oct 4, 2023 | 08:10 PM
ULTM8Z's Avatar
ULTM8Z
The main thing about the Miniram is the tuning. If it's not dialed in properly it can actually become a disappointment.
Old Oct 4, 2023 | 09:42 PM
Spencer Smith's Avatar
Spencer Smith
Agreed. Be prepared to spend a lot of time tuning if you’re doing it yourself. I’ve nearly torn mine off on more than one occasion. It’s been a rewarding headache
Old Oct 4, 2023 | 10:54 PM
ULTM8Z's Avatar
ULTM8Z
Lol!! You know it!!
Old Oct 4, 2023 | 11:24 PM
vader86's Avatar
vader86
Well a custom tune generally runs in the $500 range, and its a necessity here. Preferably the tune is done on a dyno, but part throttle is where you'll really need it, and for that you should have the tuner ride along and make logs and tweaks. This is not something I'd take on as a newbie, and you'll be hard pressed to find all that you need since Moates is out of business.
I have TPiS headers without AIR inlets and the EGR is plugged. You must retain the stock O2 sensor bung in the drivers side. I no longer have any cats.
To Comp Cam + Mini Ram, Worth it?
