early C4 A/C panel explain
Old Oct 5, 2023 | 12:13 PM
Yariv's Avatar
Yariv
Default early C4 A/C panel explain
Hi,
I'd like to know better how the A/C operates.
The MAX makes the compressor work at full power. NORM (half the power?).
B/L?
VENT? Only the blower without the compressor?
COLD/HOT slider, moves the blend heater core door?
Old Oct 5, 2023 | 12:24 PM
Yariv's Avatar
Yariv
I think I found an answer.
https://www.corvetteforum.com/forums...post1581582086
The HOT/COLD moves the blend door.
Old Oct 5, 2023 | 12:26 PM
1Hotrodz's Avatar
1Hotrodz
Originally Posted by Yariv
Hi,
B/L?
Max setting opens the recirc door in the plenum box, allowing 80% of the airflow to be recirculated thru the cooling coil and the remaining 20% of the airflow from the outside air intake (by the windshield cowl opening)
B/L is bi- level meaning air is distributed at two levels, the dash vents and the heater vent,
Vent and Hot / Cold you are correct.
Old Oct 5, 2023 | 12:48 PM
Kilobuck84's Avatar
Kilobuck84
Defrost also runs the A/C if it's above 40 degrees ambient.
To early C4 A/C panel explain
