Driveshaft limit
Old Oct 15, 2023 | 07:33 PM
rlane5's Avatar
rlane5
Default Driveshaft limit
How much HP can a C4 automatic driveshaft handle
Randy
Old Oct 19, 2023 | 11:02 AM
69427's Avatar
69427
From: I tend to be leery of any guy who doesn't own a chainsaw or a handgun.
A driveshaft is just a rotating torsion tube. It doesn't really care about horsepower. Torque is what turns it into a spiral. If no one has actual test data on those shafts, it can be calculated by knowing the dimensions of it.
However, I suspect there are only about three members on this forum who would actually do those calculations.
Old Oct 19, 2023 | 12:07 PM
vader86's Avatar
vader86
HP doesn't break it, the instantaneous torque breaks it. Hook up the tires just right and anything can happen.
I would be worried about half shafts and spindles, U-joints, and especially the D36 before I would worry about the driveshaft itself. Maybe with a silly gear ratio on launch like 9:1 or 1000 ft-lbs of torque.
Old Oct 20, 2023 | 09:20 PM
No83's Avatar
No83
Former drag racer here. Three thoughts:
1. Think of the weakest link like Vader said. My G body broke three transmissions and two rear ends (pinion on one, spider gears on other). The steel driveshaft was always fine, never an issue.
2. If you are on radials or even drag radials on the street you’ll probably never have enough traction.
3. It’s shortness helps, it is such a small distance from the tail shaft to the pumpkin - it is therefore stronger.
To Driveshaft limit
