94-96 MAF Sensor Outer Diameter Spec
Old Oct 20, 2023 | 01:18 AM
yakmastermax's Avatar
yakmastermax
Default 94-96 MAF Sensor Outer Diameter Spec
Hey all,
Can anyone with a 94-96 LT1 or LT4 really quickly measure the outer diameter of the MAF sensor were the intake ducting slips over?
I am trying to figure out if an 86-89 TPI MAF would correctly interface with the ducting that goes on either side of the 94-96 MAF sensor.
Thanks!
Old Oct 21, 2023 | 11:55 AM
yakmastermax
Bump!
Hoping someone might be able to take a few min this weekend to take this measurement!
I would but I don't have a 94-96 MAF car nor the parts to measure the dimensions from!
Thanks!
Old Oct 21, 2023 | 12:09 PM
WVZR-1's Avatar
WVZR-1
How about a new on the shelf at a 'local' supplier?
Old Oct 21, 2023 | 12:13 PM
yakmastermax
Great idea! I didn't think of that lol
Old Oct 23, 2023 | 01:09 AM
RPO Joe's Avatar
RPO Joe
From: Central Kansas – early 1977 L-48 Coupe in Classic White, aka the Sunset Stripper
2023 C4 of the Year Winner - Unmodified
Originally Posted by yakmastermax
Hey all,
Thanks!
I was gone over the weekend, or else I'd have already gotten this measurement for you. I'll grab it first thing in the morning.
Old Oct 23, 2023 | 10:54 AM
RPO Joe's Avatar
RPO Joe
To my eye, it appears to be right at 3-5/8".
Old Oct 23, 2023 | 11:02 AM
WVZR-1's Avatar
WVZR-1
Needs to be a bit more accurate than your 'Eyescope' to be of value to the OP!
Old Oct 23, 2023 | 11:18 AM
RPO Joe's Avatar
RPO Joe
Yeah, I totally get your comment, but I'm unfamiliar with these clamps and how to remove/install them...
...so I did my best to give the OP some hopefully useful data. I just very carefully re-measured the MAF housing inlet diameter, looking straight down from above, and I'm confident that my eyescope reading of 3-5/8" is within a 1/16". If the OP's MAF diameter is significantly different from this (say, 3-3/8", or 3-13/16", or...), then my measurement should be of value to him.
Old Oct 23, 2023 | 12:26 PM
WVZR-1's Avatar
WVZR-1
OEITKER clamp and in the past this ( OEITKER P/N 16700092) was mentioned to be correct but OEITKER has some very interesting options and dependent on the vendor minimums might not be an issue. The 293 style from them looks interesting.
This is a 7+ year old discussion
https://www.corvetteforum.com/forums...r-1996-c4.html
A different part number mentioned in that thread seems to be available from many vendors as inexpensively as $1.39 plus of course the ship. Do your own research!
A complete 'Air Induction Selection' is here
https://www.oetiker.com/en-us/Market...Intake-Systems
Old Oct 23, 2023 | 01:26 PM
RPO Joe's Avatar
RPO Joe
Thanks @WVZR-1 for the info. Over the several months I've been skulking about here on the C4 forum I've been building a "Helpful Corvette Links" database on my computer, and just added the above links to it for future reference.
Thanks again.
Old Oct 23, 2023 | 03:26 PM
WVZR-1's Avatar
WVZR-1
Anyone could check diameter of the MAF with a 'local' - that sensor has GM applications through probably 2004 and a person might find both metallic and plastic/composite versions of it. OE from GM I believe was serviced with clamps earlier years. Later I doubt that.
Old Oct 23, 2023 | 07:17 PM
yakmastermax
Okay found a local O'Reilly that had a 1995 Vette MAF sensor in stock. Bad news is that the dimensions don't match the 1985 sensor that I have. Good news is that it doesn't appear too far off.
I measured 3.65" inlet and outlet OD of the sensor.
Old Oct 23, 2023 | 08:19 PM
RPO Joe's Avatar
RPO Joe
In decimal form, my measurement of 3-5/8" equals 3.625" so I was off by 0.025" (25 thousandths of an inch) -- not bad for a 70-year-old eyescope.
Old Oct 25, 2023 | 07:18 PM
Hit Man X's Avatar
Hit Man X
Potentially trying to use that late MAF on your MAF L98? Curious if so, as my LT1 Fleetwood Brougham has the same.
To 94-96 MAF Sensor Outer Diameter Spec
