Help removing wires from 727 ecm plugs, please.
Old Jan 22, 2003 | 10:39 PM
Bob86ZZ4's Avatar
Bob86ZZ4
Default Help removing wires from 727 ecm plugs, please.
Okay, I am trying to figure out how to remove the original wires from the 22 pin plugs that go into the back of the 727 ecm. I got the fancy Lisle tool that looks like a star wheel with six different things poking out of it. Do I stick one of them into the hole and push the terminal out the back of the connector? I tried that but I push real hard and can't seem to get the thing to push out. I get them to push out a bit but not all the way. Thank you for any help.
Old Jan 23, 2003 | 09:56 AM
-=Jeff=-'s Avatar
-=Jeff=-
Default Re: Help removing wires from 727 ecm plugs, please. (Bob86ZZ4)
I will try to look tonight.. I have some spare connectors at home with wires..
Old Jan 23, 2003 | 01:01 PM
ZylaRace's Avatar
ZylaRace
Default Re: Help removing wires from 727 ecm plugs, please. (-=Jeff=-)
Not familiar w/ the 727.
If it is a round contact, typically you slip a cylinder over the outside of the contact to free it. These cylinders are usually specialty items. Weather packs contacts work this way.
If it is a flat contact, typically there is a single "key" that can usually be released w/ a straightened or flat paper clip.
Old Jan 23, 2003 | 01:56 PM
Bob86ZZ4's Avatar
Bob86ZZ4
Default Re: Help removing wires from 727 ecm plugs, please. (ZylaRace)
Well, it is a weather pack connector type I think. The 727 ecm is designed to be mounted in the engine compartment. The plug is a female type and the opening where the pin goes in is a very small square hole. I tried sticking the tool into that hole and pushing but it doesn't seem to want to push the plug out of the plastic casing. I'll try to add a couple pictures of the plugs. Hope this works.
Thanks for any help.
Old Jan 23, 2003 | 07:34 PM
-=Jeff=-'s Avatar
-=Jeff=-
you need a small pick or such to push on the Keyed part of the connector, that should then let you pull the pin out..
Hope that helps
Old Jan 23, 2003 | 11:32 PM
Bob86ZZ4's Avatar
Bob86ZZ4
I'll try it again tomorrow, I'm gonna take the plug to the dealer and see if anybody there can show me. I'm very dumb in case you couldn't figure that out already.
Old Jan 24, 2003 | 09:53 AM
ZylaRace's Avatar
ZylaRace
Sliding a pick/solidWire device between the connector and the contact lock should release it. The contact lock should be positioned on the bottom of the connector hole, (as your pic is posted).
Old Jan 24, 2003 | 01:52 PM
Bob86ZZ4's Avatar
Bob86ZZ4
Thanks Zyla. That's it. Then I find out that new connectors are .89 each. So, I decided to leave the connectors in the big plug and I'm just gonna have to use those butt crimpon connectors to make my splices up. The project continues.
To Help removing wires from 727 ecm plugs, please.
