93 oil pan leaking again ?
Old Oct 30, 2023 | 09:20 AM
radar502's Avatar
radar502
Default 93 oil pan leaking again ?
Anybody know why my 93-oil pan starting leaking for no reason?? 3500 miles back was replaced with a Fel- Pro gasket bam starting leaking was fine no problem I snugged it up a little didn't help, I don't get it. going back with a newer stock one with lots of gasket sealer??
Old Oct 30, 2023 | 11:03 AM
Topduarte's Avatar
Topduarte
My 94 did the same thing near the starter after 300 miles. I gotta go back and redo it. It's not much but it annoys me.
Old Oct 30, 2023 | 11:34 AM
radar502's Avatar
radar502
Default 93 oil pan leeks
I don't get it either ,I put in the uber Felt -Pro gasket (Guess NOT) The Org. gasket lasted130,000 the so-called uber gasket 3500 miles .The trans was out just seeping a little good time to change it ... I don't get it ... Not a easy job .. These old vettes .
Old Oct 30, 2023 | 09:14 PM
1985 Vette's Avatar
1985 Vette
How bad is the leak? My 88 and my 85 both have small oil leaks. Can't seem to find them (nothing obvious like pressure gage or valve cover). They are small (a few drips after sitting like a week). I'm willing to let it go until I'm into the engine for something else.
I don't know the LT-1 engines at all, but you need to put a value on your time and if a small leak is worth it.
Old Oct 31, 2023 | 08:36 AM
radar502's Avatar
radar502
Thanks for the replay, yep leaking on the driver's side can smell it and see some smoke so another new gasket. I use the dye kit it seems to work if can't find a leek. My time and valve (right) have been charging myself $135.00 hr. deiced to give myself a rase now $150.00 hr.
Old Oct 31, 2023 | 10:48 AM
FostersPerformance's Avatar
FostersPerformance
You only need the UV light as all motor oil has dye in it. You can add some to the oil if you need to, and it will really stand out where the leak is. Clean everything up best you can 1st.
To 93 oil pan leaking again ?
