C4 88 strange MAP behavior
Corvette C4, 88, L98. When warms up - almost every time during the regular driving car spontaneously (single time) starts shaking under load and immediately gives 33 code (SES), which means High MAP. I made a diagnostic based on googling, service book and forums - cleaned all contacts, replaced both relays (burn-in and power), cleaned MAP, replaced IAC and set TPC at 0.55 - same result. Restarting the engine removes SES light, but then it appears again after a couple mins of driving. I connected ADLD cable from RedDevil and used ALDLroid app to log the car behavior - and MAP signal looks very strange for me - most time it shows 0, and appears only when I'm pressing throttle. The signal usually not high (0.5-0.8 V), however, after a while - it becomes way higher (4-5V) during the same style of driving. Seems like this is exactly appears when I receive code 33. O2 sensor diagrams looks good to me - at the beginning it smoothly goes high and then becomes erratic. Do you know where should I take a look? (diagrams are attached)
Try A028 or A059. Note: the 86-88 and 89 datastreams are very close with only a few bytes that differ between them. I use my own adx files with ALDLdroid, but I will take a look at the provided ALDLdroid adx files.
More info: https://www.corvetteforum.com/forums...post1606633915
So I just made additional logging by using 2 different .adx and 2 different applications - ALDLroid (.adx name - A028-L98-LB9-1985-1988-9600.adx ) and TunerPro RT (1985 5.0 (LB9) TBI F Body & 5.7 (L98) TPI Y Body 1226870 $1F.adx). The results a bit different now and MAF seems more stable, but the issue with SES (code 33) still exists (same behavior). For some reasons none of .adx files logs Code 33, but it can be read with paper clip method. During both tests I found strange behavior of IAC sensor - in the middle of the diagram - it falls to almost <20 steps for a second. But I replaced it about a month ago. Open loop during all 15 mins driving though.
TunerPRO with IAC falling
ALDLroid with 028 adx
If you're going to use the ALDLdroid provided adx files, I would suggest that you use A059 (A059-L98-LB9-1989-9600.adx) for 8192 baud scanning, but make note of the $32B/$6E datastream differences that I posted in the link above (irrelevant with one exception since this adx doesn't decode every single bit and byte included in the 63 byte datastream: the Burnoff Failure Check Complete flag is not used in $32B).
Monitor the MAF signal with respect to the throttle position. Also compare the MAF signal to the unlimited airflow signal (which is labelled as the MAF Raw Input in the adx file).
Side note: Code 33 should only be set under relatively light load conditions. It should be only set below 14.8% tps (approx. 1.10 tps volts). It is a plausibility check of the maf sensor signal with respect to the throttle position. Likely cause is an open circuit on the maf signal wire.
; ERR 33 Params, TYPE 32 ECM
; >> MAF Sensor Hi <<
LC210: FCB 38 ; If TPS >= 14.8%, disable ERR #33
LC211: FCB 45 ; If Air Flow GT 45 gm/sec, SET ERR #33
LC212: FCB 96 ; If > 600 msec, Set code ERR 33, (Num + Arg * 160)
LC213: FCB 8 ; 800 msec, ERR #33 Min time req. (Num = Arg * 10)
LC214: FCB 128 ; If RPM > Disable ERR 33, (TBL1, NTRPM) 2200 RPM
LC215: FCB 100 ; If Pump Volts <= 10 vdc, Bypass ERR 33
@C409 - Yeah, thats a good point! The difference between Gauge and ECU is about 50 degrees - when I had 150F in the dash, scan showed 100-110F. Ordered cooler sensor to check if this is an issue.
It may take some time to connect and may work better trying to connect with the engine running.
[utag=179306
