Dash fuel problem
Old Nov 3, 2023 | 12:32 PM
Acheleon's Avatar
Acheleon
4th Gear
Default Dash fuel problem
Just bought a 1986 c4 corvette and i don't think the mpg to range ration is right, any idea on what's going on?
Old Nov 3, 2023 | 02:14 PM
s carter's Avatar
s carter
It's a learning process, if you hit reset/ reconnect battery it's dumb. So if you're on a fresh reset and drive like it's stolen hance the 9mpg or if you have a long history of pure idle or driving hard 9mpg.
So reset drive on nice flowing 65/70 mph traffic for 100 miles 27 mpg.
Unlike newer cars that reset when tank is filled these don't so you can have a lifetime average or last 30 seconds
Just a thought could 9.9 be 19.9 a missing digit
Old Nov 5, 2023 | 10:07 AM
Incorvettei's Avatar
Incorvettei
I had a similar issue so I pulled the fuel pump from the tank, moved the pump unit and saw very little change. Next I opened up the sending unit and cleaned it with WD-40 and Q Tips. Reassembled and it has been working perfectly ever since
To Dash fuel problem
