Code 76 Help
Old Nov 25, 2023 | 03:16 PM
GeorgeMB's Avatar
GeorgeMB
5th Gear
Default Code 76 Help
I just replaced the Opti in my 92/base/manual and during the initial test drive the Service ABS and ASR lights came on. Checked the codes and pulled a 76 for the Accelerometer Out of Range.
I did disconnect the wiring harness clips and hose from the ASR to move it out of the way to change the plugs and wires. Never threw the code before this. Checked all the connections and all was right.
Any ideas outside of the actual Accelerometer being bad? Since I did disconnect the wires and hose, is there anything I should've done afterwards that might be causing the code to be thrown?
Btw...the Petris Opti is working great.
TIA for the help.
Old Nov 25, 2023 | 04:42 PM
GeorgeMB's Avatar
GeorgeMB
5th Gear
Thanks...I did clear it a few times.bit it comes back.
Not sure if it was just a.coincidemce.since.i disconnected the ASR or what.
Old Nov 26, 2023 | 12:41 PM
ChumpVette's Avatar
ChumpVette
If I the lateral accelerometer in like the 90-91, it has a little pendulum in it that can get stuck and not centered. If you remove it and slam your hands together with it, that will free it up.
To Code 76 Help
