Blower motor issues
Old Dec 10, 2023 | 01:50 PM
Jedikilla87's Avatar
Jedikilla87
5th Gear
Default Blower motor issues
I have an 87, and cannot figure out what is wrong with the blower motor. The 5amp fuse just above the blower motor keeps blowing when I try to use the fan. I’ve tested motor on 12v battery and it turns. I’ve tried a different blower motor control module (resistor) that I picked from the junk yard. Same results. I also plugged in a different AC head unit in car and still fuse keeps blowing. Not sure how to trace or what to test next. Any help is appreciated.
Old Dec 11, 2023 | 07:42 PM
Jedikilla87
5th Gear
So, I’ve done the tests that the service manual says to do and I have found the brown signal in wire to be in question. The book say check for a short. Now to do that I’m assuming I need to check for continuity at the end that plugs into the head unit and the end that plugs into the resistor?
