OBD1 Port not functioning
Old Dec 29, 2023 | 05:32 PM
Vic_H's Avatar
Vic_H
Default OBD1 Port not functioning
I am having trouble with getting my obd1 port to show codes. I had used a paper clip before to short the pins to get error codes to flash but recently it has stopped working. I also have a aldl data logging cable that I cannot get to connect either. When testing the 2 pins I got a voltage of about 5.
Old Dec 30, 2023 | 08:54 AM
tequilaboy's Avatar
tequilaboy
What year car are we talking about?
For 86-89 cars: Open circuit voltage on Pin B should be 5 volts and near zero when shorted to ground (Pin A). You need a 10k resistor across pins A & B (which should pull down the Pin B voltage to about 2.5 volts) in order to initiate ALDL scan data, otherwise the ecm will be sending data to the dash. What is the resistance of your paperclip? Check to be sure that Pin A is really grounded.
Here's a log showing Pin B voltage (which was added to the datastream for testing purposes) with/without 10 k resistor: https://datazap.me/u/tequilaboy/aldl...rk=232-252-273
Old Dec 30, 2023 | 07:32 PM
Vic_H's Avatar
Vic_H
It’s a 1990, I’m not sure of the resistance on the paper clip but I even went to the extant of buying a obd1 “reader” which is really just a device that grounds the pin required for the service engine codes or the abs codes. When I used the reader for abs it flashed like it was supposed to but I got nothing for the service engine light.
To OBD1 Port not functioning
