C4 Transmission issue
Jan 5, 2024 | 12:26 PM
5th Gear
I have the manual 4+3 transmission in my 1985. Until the engine temp reaches 144 degrees, there is a grinding noise. What is the cause of this and how can it be repaired
Jan 5, 2024 | 12:55 PM
Id say the main bearing in the OD is dying.
Jan 5, 2024 | 12:59 PM
Wait... that guess was on the assumption that your sound is coming from underneath in the tramsmission area. You didnt specify, so i take back my guess until you do.
Jan 5, 2024 | 01:51 PM
5th Gear
Quote:
Originally Posted by
2011KLR
Definitely coming from tranny
Jan 5, 2024 | 02:11 PM
5th Gear
Also, why would the noise disappear when engine temp hits 144 degrees? Thanks for the reply.
Jan 5, 2024 | 02:13 PM
Does it also coincide with the OD kicking in? There is a temperature where the ECM allows OD to engage. Mine is around 133 indicated.
Jan 5, 2024 | 02:39 PM
5th Gear
2011KLR
It seems to coinside with the OD kicking in because i can feel it kick in. Always happens at 140 degrees.
Jan 5, 2024 | 02:50 PM
Watch this....
Right at 9 minute mark, he says what is most likely happening. Stop driving the car right away.
sre
Jan 5, 2024 | 03:07 PM
5th Gear
