Cold Start Injector
Old Jan 26, 2003 | 09:51 AM
joalyons's Avatar
joalyons
Default Cold Start Injector
If I get rid of my cold start injector on my '88 how do I get enough fuel? Do I just reprogram the ECM to add more fuel when its cold?
Old Jan 26, 2003 | 09:57 AM
dgoodhue's Avatar
dgoodhue
Default Re: Cold Start Injector (joalyons)
If you have an Automatic, you can use a PROM with 89 code which eliminates the cold start injector.
Old Jan 26, 2003 | 12:28 PM
Cooter's Avatar
Cooter
Default Re: Cold Start Injector (dgoodhue)
:iagree:
I updated the prom in my '86 to the ARAP code for an '89 and like the results. I was told the extra timing would cause spark retard problems with my iron heads, but I have not seen it yet. Just remember to disconnect the cold start injector when you swap to the later program code.
Old Jan 27, 2003 | 06:13 AM
joalyons's Avatar
joalyons
Thanks I knew there would be an easy answer and somebody here would know it.
Old Jan 27, 2003 | 08:47 AM
scorp508's Avatar
scorp508
You'll be fine without doing a thing, but if you need to you can have the Crank Pulse Width Multiplier vs. Coolant Temp in your ECM modified.
To Cold Start Injector
