383 stroker kit
Old Jan 26, 2003 | 03:29 PM
85vettelovin's Avatar
85vettelovin
Default 383 stroker kit
Does anyone make a decent stroker kit? I am looking for a pretty good performance package, but nothing that would turn this into a drag car, still a daily driver. Or would I be better off just piecing together my own?
Old Jan 26, 2003 | 03:47 PM
atotalnincompoop's Avatar
atotalnincompoop
Default Re: 383 stroker kit (85vettelovin)
buy a kit and buy forged parts :yesnod:
I peiced together a stroker and huffed it the same year :nonod:
Old Jan 26, 2003 | 04:23 PM
johnboy89's Avatar
johnboy89
Default Re: 383 stroker kit (atotalnincompoop)
GM Performance Parts offer a 383ci short block (part# 12498332). You can see it at http://www.spoperformanceparts.com/
[Modified by johnboy89, 4:25 PM 1/26/2003]
Old Jan 26, 2003 | 04:30 PM
CFI-EFI's Avatar
CFI-EFI
All forged is nice, but not necessary in many cases. I don't think ANYBODY (including Chevrolet) makes a cast rod. Except for some late model PM (powdered metal) rods, ALL, are forged. For street and an occasional 1/4 mile blast, a cast crank and pistons will do nicely. A step up to hypereutectic pistons IS a good idea. Seriously consider 5.7" and maybe 6" rods. A "kit" may have some built in "quantity" pricing. Don't forget the damper and flexplate/flywheel you'll need. A balancing "option", may save money in the long run. You WILL want it to be balanced somewhere along the line. You don't have to go nuts (or broke) to build a good running daily driver. Have fun. Good luck, and...
RACE ON!!!
Old Jan 26, 2003 | 04:43 PM
vader86's Avatar
vader86
Default Re: 383 stroker kit (CFI-EFI)
Summit sells 383 kits, but i would piece together parts from various suppliers.
I suggest you order a Summit and a Scoggin-Dickey catalog and look through them.
Old Jan 26, 2003 | 09:34 PM
Raistlin's Avatar
Raistlin
http://www.flatlanderracing.com/ was recomended on this board before, i've personally have no experience with them.
Old Jan 27, 2003 | 05:15 PM
gtsyellow's Avatar
gtsyellow
Default Re: 383 stroker kit (Raistlin)
same with the ebay sellers, you could make a really strong 383 kit real easy. scat makes a $200 383 crank, eagle has a bushed i beam 6" rod for $210, wiseco sells a piston & ring combo make for the before stated in summit for $400ish. take your pick of bearings and assemble correctly & you just made a short block that can live as long as your stock block does.
Old Jan 27, 2003 | 06:17 PM
yoslambo1@cs.com's Avatar
yoslambo1@cs.com
i dont know where you could buy a kit but if you want to buy a crate check out http://www.allchevyengines.com ! :cheers:
Old Jan 27, 2003 | 06:40 PM
Togo's Avatar
Togo
i bought my kit from allen motorsports in dallas texas....GREAT CUSTOMER SERVICE!!!!! his number is in qwestdex.com!!!!!
look him up and tell him what you want.....there were several good posts about this guy AND his shop!!!! :cheers:
[Modified by 85_togo, 4:40 PM 1/27/2003]
Old Jan 27, 2003 | 10:21 PM
jimmyd's Avatar
jimmyd
My engine builder is going with a eagle kit, 5.85 rods, cast crank, (im not going to use a blower, turbo, or n2o,) it will be mostly a street car.
Old Jan 28, 2003 | 05:21 AM
Cratzy's Avatar
Cratzy
Default Re: 383 stroker kit (jimmyd)
I have heard different things about Eagle; some of them are not very good...
I would like to hear your opinions. My mechanic doesn’t want to put in anything from Eagle in to my car, he says that I should go with Callies, Manley and brands like that. If I could put in Eagle that would be much cheaper.
Thanks and sorry for the hijacking.
BR
Kristoffer
:cheers:
Old Jan 28, 2003 | 06:25 AM
LD85's Avatar
LD85
Default Re: 383 stroker kit (Cratzy)
http://www.speedomotive.com
http://www.martelbros.com
http://www.competitionproducts.com
http://www.strokerkits.com
Old Jan 28, 2003 | 01:39 PM
bubbaray's Avatar
bubbaray
I have built several storker motors and the best qaulity for the buck I get from Powerhouse. I have never had one come back. Their kits start at $469. and thats for al most everything but the block and heads. Check em out. http://www.enginekits.com
Old Jan 29, 2003 | 06:01 AM
gtsyellow's Avatar
gtsyellow
if he can't resize the stuff i agree. the problem with eagle is the quality control. the metal is strong and the forge is good but the clearances aren't. my $200 scat crank and my $200 eagle rods had to be worked and machined to get the main clearances i wanted. it's really not that hard to do, same with the balance, spin it, grind, spin it, grind. the really really high end stuff is definatly more exact but a good engine builder can clearance anything. someone who insists on the best for street/strip driving i would question.
Old Jan 29, 2003 | 02:02 PM
85vettelovin
Thanks for all the info guys, I will keep looking around. Eventually I might be running some N20. I hear good thing about Ross pistons but they seem a little pricey
To 383 stroker kit
